Hello, I have thought that it could be cool, interesting and artistic if it could be possible to swap or replace a group or range of same color tones (all the red tones, or all the blue ones...) with one you may sel ect with color control component and that the range of colors is kept but changed with the range of colors of the selected custom color
It should be possible to replace ANY possible range of colors in the same image, what I mean is to be able to replace or swap optionally just one range of color or the whole image source palette
I choose to change all the range of red tones with some blue tones and generate all the gradients in between
For example here is replaced from the original source palette and replaced some of the original colors with other ones
or this other example that it makes mostly yellow
Or this one
In the 3 above examples is replaced most of the original source colors and this is good but I do not know how this can be done especifically, because using gradients maps will not work because the effect is applied IN ALL the source colors and NOT selectively, so then should be another way, what happens if what I want is to do it in a selective optionally way, so it I just want to change ONLY the reds and not any of the others it could be possible. or change first the reds and then see how it looks, and then change the blues, etc.
I think I would need some kind of palette swap or palette extraction to be able to change them
If you search for Replace color or color swap in filter library, appears filter that will replace ONE color but not a range, at least what I have found
Palette Swap thread in FF forum with interesting things
I have found this filter that is able to extract a color range and isolate it
Color Range Picker with Median By Rachel Duim
I have just found this other filter that I do not know how it works and if it is able to replace range of colors
Changing Seasons By Rachel Duim
This filter changes 1 or 2 “match” colors to another range of colors. This allows “seasonal” changes, for example changing green to yellow, red or orange.
Or maybe this other one
Poor Man's Palette By Indigo Ray
Using just a "blend" (difference mode) and a "treshold", you can pick a single pigment, find other colors that look like that pigment in your image, and replace those colors with the pigment, all at once
The idea behind this idea comes from this other thread
How to create a thermography effect filter for images inside FF
24 unregistered users.
