I have seen this thermography effect on these images here below and I have searched for thermography filter filter on library and forum and there is no reference
So If would like to be able to make a similar effect with filter forge So here is one of the examples where the first image in the top left is the original and the others are the thermography variations |
| Posted: August 14, 2021 4:41 am | ||||||||
| Posted: August 14, 2021 4:44 am | ||||||||
| Posted: August 14, 2021 4:51 am | ||||||||
| Posted: August 14, 2021 4:52 am | ||||||||
| Posted: August 14, 2021 4:54 am | ||||||||
Also It can be even better adding additional colors to the gradient ax shown here
The top left on the grid is the original one |
| Posted: August 14, 2021 5:03 am | ||||||||
As you can see on these ones from previous post It really can change much the effect from a plain gradient monochrome
The last one here is taken from this product available here And here another cool conversión from a boring dark object to a colorful one |
| Posted: August 14, 2021 5:05 am | ||||||||
| Posted: August 14, 2021 5:14 am | ||||||||
| Posted: August 14, 2021 5:15 am | ||||||||
| Posted: August 14, 2021 5:18 am | ||||||||
| Posted: August 14, 2021 5:21 am | ||||||||
From the Library I have found only these two filter that may be similar to what I have shown above BUT after testing it, it does NOT work in the same way and the result is not the same using the same original images shown in the examples
Psychedelic Remap By James |
| Posted: August 14, 2021 6:55 am | ||||||||
| Posted: August 14, 2021 6:58 am | ||||||||
Please, do you know any other possible filter that can do something similar ?
Thanks very much |
| Posted: August 14, 2021 6:59 am | ||||||||
| Theob |
I have got an idea. Will try to make one to see if it fits
| Posted: August 14, 2021 10:40 am | ||||||||
Thanks very much for trying to do something with this. |
| Posted: August 14, 2021 2:11 pm | ||||||||
I have found something that may be useful
So if you search for infrared as source for trying something similar and is using this filter Infrared by Betis
this filter by itself does not give at all the effect wanted, but maybe changing the gradient map used could be maybe be useful, do not know, have to test it. And also I did remember that StevieJ had made something maybe similar in some way that could be modified to make this above, here below is a screenshot of page 3 search of StevieJ filters |
| Posted: August 14, 2021 2:17 pm | ||||||||
| Theob |
Could this be ?
PS: perhaps using rainbow gradient and a loop to have a wider range of colors. Sorry if i am wrong, still fresh and still learning haha Infared.ffxml |
| Posted: August 15, 2021 12:56 am | ||||||||
I have made some tests with the Infrared filter by Betis, but yet have not had any results that are good, but maybe could it be possible using different gradients
Thanks very much for making it, much appreciated I have made some tests and at start it did not work, but after adding all the controls and sliders, it seems that is cool and interesting way of doing it and it can be something that could be used. Although it needs to have much more testing and configurations to see IF this can be really a thermography filter or is just a cool coloring filter Is needed to test and find the right presets settings and values that can give good results So here below is the first alpha testing with just one preset Thermography Coloring Testing.ffxml |
| Posted: August 16, 2021 4:45 am | ||||||||
| Posted: August 16, 2021 4:50 am | ||||||||
| Posted: August 16, 2021 4:51 am | ||||||||
| Posted: August 16, 2021 12:01 pm | ||||||||
| Theob |
So i tried again with loop and rainbow gradient so they kinda have wider color range.
Ps: Your modified version works pretty well tho. Thermography v.101.ffxml |
| Posted: August 16, 2021 12:12 pm | ||||||||
| Theob |
Whoops...duplication
| Posted: August 16, 2021 12:14 pm | ||||||||
Hello, Theob, thanks for the update will see how it works and what can be done
I think we are doing it wrong, in the part that it seems that all the filters and software that use this thermography effect are using GRADIENT MAPS to create this thermal effect, so will see how this can be used I think that maybe what would be needed is to replace the original palette of colours for a new one designed with gradients, but FF does NOT allow to import gradient maps from an external source, so they need to be created by hand Maybe the gradient could be applied at the end of your filter, do not know, have to test. Well, will go and test your neew 1.01 version, thanks |
| Posted: August 16, 2021 12:28 pm | ||||||||
| Theob |
Hello, i see what you mean now. So it was wrong since the beginning haha. I thought it was something to do with the channels themselves. Perhaps elevation gradient could be used as gradient map instead ?. Let me try it again. Cheers !
| Posted: August 16, 2021 12:47 pm | ||||||||
| Posted: August 16, 2021 5:27 pm | ||||||||
Here is the code. FF7 and above. Very simple use of HSB to create an elevation map. Most thermographs are 5 color (BCGYR, coolest to warmest). Another adjustment would be changing the gradient positions...
Thermographic Map.ffxml Math meets art meets psychedelia. |
| Posted: August 16, 2021 5:34 pm | ||||||||
chrisd
Posts: 51 |
Isn't this purely arbitrary, I mean, you want something that looks "close" but it may not match the actual gradient? .... there's no way way to code the specific color gradient, as you say " ... FF does NOT allow to import gradient maps from an external source, so they need to be created by hand" The goal is to create something that "looks" right but may not be technically correct? |
| Posted: August 16, 2021 8:32 pm | ||||||||
Yes, it is arbitrary. False coloring, a favorite of graphic artists and painters for a long time. So I agree, going for a look not technical accuracy is the point
| Posted: August 16, 2021 9:22 pm | ||||||||
| Theob |
Woa, It is simply awesome
| Posted: August 16, 2021 10:28 pm | ||||||||
No, I do not mean that you was wrong in any way, your idea is right and well, I agree that maybe if you want to have an accurate technical termography it may not be the right way, but I did like your idea and how you have done it and it can be expanded and mixed with other things to make it better.
YES, you are right, sorry that I did not tell this from start, I do NOT want to have a perfect technical correct simulation of a thermography effect, I just want something that "looks like" the effect but does not need to match the real effect, and can be much different colors.
Yes, I agree, that it should not really be called Thermography, it could be called Gradient map coloring, or false gradient coloring, or Look up Coloring, as the Thermography by itself is limited |
| Posted: August 18, 2021 5:41 am | ||||||||
Sorry that I still have to see how it works, and will value it, and I still think that this could be useful and great in some way, even if it is not like "thermography" because it also looks cool and artistic And as I say below, I may mix your filter with the one made by Rachel
OH!! Thanks very much for your own version of this filter, much appreciated your help, this looks very good and well done, and like it how is done, although I also like Theob version, so maybe I could mix both in some way. So I will continue trying to make it even better and more flexible and with more options to change the colors in more wide way, because THIS IS WHY we use filter forge, it lets you have a great potential to extend and modify something beyond it´s original use and have it much more customizable if possible Here is available the Rachel Duim version WITH some added additional controls and with adjustments controls too. Sorry that this is only for FF 10 Thermography Coloring Testing Rachel.ffxml |
| Posted: August 18, 2021 5:50 am | ||||||||
