Ken
CameraKen
Filters: 16
Ideas.
Hi FF Team.
First of all, Thanks for the new version. It is much faster and the new features are great. smile:)
Here are a few ideas and comments to improve it even further
Order of controls
The new ‘Order of controls’ is great but how about Titles and Separators maybe even the options for Bold and text color Etc.
Also
The order of controls at the permalink now do not match the order of controls in the filter
Frame Component.
This is much better than I could have hoped for. It works great and is very fast.
But it could be improved further with more inputs. Separate inputs for top, bottom, left and right and maybe corners would give many more possibilities. (Or a more intelligent frame component) An example would be for adding grain to a wood frame. The grain should be horizontal at the top and the bottom and vertical on the sides although I have just about got a method for this, but extra inputs would be easier.
Drawing
I know this has been mentioned in other threads, and I understand the reasons for not being able to import images, so let’s have a basic drawing tool.
Some shapes are difficult to make from gradients etc but would be so simple with a brush. Drawing could be recorded (like a PS action) and then manipulated like noise or patterns. For example, look at the code for Mike’s superb Barbed Wire fence. Or ‘Hello World’, a simple brush tool could have made these much easier to build.
Zoom Workspace
The new zoom in the filter editor is great and a much needed improvement, however it is too domineering. Every filter I open defaults to max zoom out and I now have to zoom back to normal before working. This is becoming a little annoying. Could we have a ‘remember zoom’ setting so that we can set up a default zoom.
Lastly
A couple of questions to save starting new threads.
I notice that frame and border filters are dropping into ‘Effects’ and ‘Textures’ sections. This is because they can be made with and without the Image component. Where would you prefer them to be?
How can I delete a filter?
I have tried to update ‘Page Curl’ with the frame component but I cannot find a way. I can make it work again but I would be using a similar method as before. It may be good to start a thread where we could post filters that require deletion. Would you prefer that I delete it or repair it?
What does the ‘Fixed Size’ checkbox do in the frame component?
Thanks for listening.
Ken.
Looks like a bug -- I'm assigning it to the programmers.
The Texture/Effect distinction is automatic. The logic is simple: if a filter needs user-supplied data, such as Image, Selection, Minimum, Maximum or Average, it is considered an Effect. If a filter can work without external data, it is considered a Texture. The Frame component doesn't affect this distinction (despite being located in the External category).
Currently, there's no way to do this on the user side, so you can submit a request via our contact form -- don't forget to include a link to the filter you want us to delete.
When it is turned on, the global Size control doesn't affect the frame width. When you turn it on, the Size slider will affect the frame.
Ken
CameraKen
Filters: 16
Thanks Vladimir.
I got it now. I could not see what it was doing
Ken.
I'll add this to the plan. By the way, how do you zoom in/out in the Editor -- mouse wheel, hotkeys or toolbar buttons?
Ken
CameraKen
Filters: 16
Thanks Vladimir.
I am mainly using the mouse wheel. The problem is that the zoom always tries to centre on the results component. It would be nice to be able to zoom out, move to the area of the filter I want to work on and the zoom back in. But this is difficult; I have to keep repositioning the centre.
Also, very often I want to move between the editor and the main window (to see the results so far). Every time I go back to the editor I have to zoom in and re-locate the component I was working on. What would be really nice is if FF remembered the zoom setting and the location on the workspace so that I was taken straight back to the component I was working on.
Ken.
Mike Blackney
Filters: 57
That's quite strange. On my system, I can zoom out using the scrollwheel, position the mouse over the component I want to zoom in on, then zoom in on that component using the scrollwheel. If that doesn't work for you, maybe it's a bug?
Ken
CameraKen
Filters: 16
Hi Mike.
After reading your reply I tried again. You are correct. What I have found is that the scroll wheel zooms into the area where the mouse is positioned.
I expected the scroll wheel to just zoom in and out (irrespective of the curser position) but I now find that I can zoom out, and then position my mouse at a point where I want to zoom in and then the scroll wheel zooms to that position. That’s great. Thanks for making me look at that again.
smile:loveff:
Ken.
Mike Blackney
Filters: 57
smile:loveff:
You're darn right, smile:loveff:! Anytime smile:D
