Right now you have to pan over if your on something else.
Huh?
Mike Blackney
Filters: 57
That's what I thought smile;)
Maybe uber's after a hotkey or checkbox that displays the result node in the preview window, overriding whatever node is selected or locked. That way, you could quickly view the result without having to pan from one side of your filter nodechart to the other.
Thanks for translating Mike. smile:D
Lucato
FF addicted
Maybe toggle by using 'space bar'. smile;)
Currently we don't have a hotkey for this, but there's a workaround. There is a hotkey F to select the Filter Controls, and when you press it, it shows the output of the Result component in the preview window (unless it is locked onto another component).
11 unregistered users.
