Please, could you be so kind if is technical possible to put the Notes appear in the back of the Components and NOT IN FRONT of the components?
I mean that they would appear in the background and when you move them it will not be overlay over the components.
The Notes component is really awesome and very helpful and useful and you can make a note and you can make it huge and put a lot of text but it must be always outside of any component.
Why I ask for this? Because then you could be able to make this that Skybase has shown and be able to group all the components that the note is related
Regardless here's an interface of Quartz Composer. Note how detailed the notes are and how intuitive the interface is. We're not dealing with just nodes that make no sense. We're dealing with words not just nodes.
This would be really helpful and bring more use to the Notes
here below is the original bigger version as pasting the images from other forum thread does not allow to zoom it.
I have just seen that really the only problem with the available notes, is that the notes is OVER the components and not behind the components
There is more information about this in this other thread
Have larger notes in FF 9 to put groups of components inside the note
Although the name of the thread is wrong because on FF you can already make the Notes very large and there is no limit in size
And is not needed at all to change the color of the notes, having all them in yellow is right as shown here above
Thanks Sphinx for the answer to know that this wold not be possible without much work.
