Drag a connected component on top a note component:
connections are behind note, component is on top.
Confirmed, thanks for testing!
if possible it would be great if the Note component always stayed behind other components. This way it could be used to show a certain relation/context between the note and a set of components smile:-)
I'm afraid it would require a rewrite of the entire z-order logic...
If you need to comment on a set of components (rather than a single component), our suggested workflow is to combine the components into a group.
12 unregistered users.
