Hello,
I have had an idea that as you can´t make your own folders to organize filters, and you can´t rename the categories, and can´t arrange the filter in another way, I have had the idea that I could organize the filters using my own Keywords added to the filters. So I could add for example the keywords Fav1 as the ones I like most Fav2 Fav3 Fav5 so it would be like a rating And so I do not care at all where they are stored in whatever category, I just need only to use the FF search on my own FF library inside FF to find them. And also I could add others keywords to categorize much more the filters and could be like virtual folders, I mean instead of folder names, it will be keyword names. WHAT IS THE PROBLEM TO BE ABLE TO DO THIS ? I do not know how to change the keywords inside my own FF filters library, as when edited with the filter editor you can´t put it back to the original place. Should I edit each one in the filter editor, save to "my filters" folder and then manually overwrite the old one with the new one in the FF library? Please, see this other thread here |
| Posted: November 16, 2011 4:54 pm | ||||
I have now tried to make this: 1 - modify keywords in a choosen filter inside filter editor 2 - save it to "my filters" folder 3 - Go to the "my filter" folder using the SHIFT L (after selecting a filter in FF) 4 - Copy that filter 5 - Go to the Filter library folder and FIND THAT IS NOT POSSIBLE TO PASTE IT THERE !
Because the filter saved in "my filters" is with the name I have choosen and inside the FF filter Library ALL the filter names are like this "Library_6118-1" so is not posible to overwrite the same modified filter because you do not know what is the name of the same filter inside the FF library. |
| Posted: November 16, 2011 5:42 pm | ||||
I have thinking of possible solutions but I do not find any
Please, Please is there some way to do it ? Or this is really a feature wishlist ? Thanks |
| Posted: November 17, 2011 1:41 am | ||||
Posts: 3503 |
It is really a feature request. I've moved your other thread on this topic in the appropriate forum.
| Posted: November 17, 2011 2:10 am | ||||
Thanks for moving it to the Feature request forum It is very sad that this is really something that can´t be done
I do not understand why this is not possible ??? If you can modify all the info of the filter, why you can´t save it again to the filter ????
Please, Is there any technical reason for this is not possible ? |
| Posted: November 18, 2011 1:07 am | ||||
I have just found this thread, and I am very happy that this will now be possible thank to the kind and great work of Morgantao with his new tool he is developing, please see it here
| Posted: April 8, 2012 4:01 am | ||||
33,825 Registered Users
+12 new in 30 days!
+13 new in 30 days!
15,384 Topics
