Frank2
Hi All, smile:)
First of all, forgive me if this has all been asked before, but I don't follow these forums very closely (read: not at all) these days.
Question - is there any downside in upgrading to Filter Forge 2.0? Apart from having to pay again for FF, of course.
I ask because I recall FF has this amusing trick of deciding to re-organise all my filters all over the place sometimes when I've just added a new filter, er, just because it can. Oh, how I appreciate that one!
Bearing in mind, that I also have literally hundreds of other plugins and have seconds to decide which one (or combinations of) to use for an effect and so have to memorise all this lot, then I'd rather stay with the FF version I have than go through that random rejiggling of the filter lists all over again.
So, any surprises? anything else I should know? any date for the discount being 120% or something? smile:)
Mike Blackney
Filters: 57
I can see no downsides to upgrading to version 2.0, so long as you can afford it. It's seriously better, like a whole ton better.
The filter category will potentially be updated, but that's no different from the old versions. If you keep your old version then you're going to miss out on many new filters since most contributors who have version 2.0 won't make filters for 1.x, even if the filter they're making would be possible in a legacy version.
If you don't want filters to move then you could just edit them and save the filter -- then it will appear in your own filter list under whatever name you give it. Call it "BUILDING_blah" or "001 - blah" or whatever else you'd like. If you often use your own filters then you can copy them all across to the new version. It's a very small change that only happens occasionally, and it's nowhere near as bad as Adobe's constant abusive changes to the interface for Photoshop (don't get me started, I could be here all day!)
Frank2
Thanks for your thoughts on this, Mike. It's much appreciated.
Totte
Übernerd
Filters: 107
Frank2 :The Lighting and Ambient Occlusion in 2.0 gives a whole new life to many old 1.0 filters.
15 unregistered users.
