Jason Rodriguez
Posts: 2 |
Hi,
Can you get access to per-pixel RGB values as a triplet array (so basically some sort of per-pixel seperated component output like pixelValue[x][y] would return a pixelColorValue[r][g][b])? |
| Posted: July 19, 2006 2:21 am | ||||||||
Administrator |
Jason, there is an ExtractRGB component in channels, but it is not per-pixel -- internally, Filter Forge doesn't operate on pixels.
Could you please describe what you're trying to do? I had an idea about a Color Picker component that would allow extraction of color from a point at specific coordinates, but the idea wasn't finalized enough to be included into the beta. |
| Posted: July 19, 2006 5:46 am | ||||||||
Mike Blackney
Vladimir wrote:
I had an idea about a Color Picker component that would allow extraction of color from a point at specific coordinates, but the idea wasn't finalized enough to be included into the beta. It's not too hard to do ourselves anyway. The attached filter is one example Pixel Color.ffxml |
| Posted: July 19, 2006 6:20 am | ||||||||
byRo
Drats, must get up earlier - Mike beat me to it!
Rô RGB Picker.ffxml _________________________________
My favourite question is "Why?". My second favourite is "Why not?" |
| Posted: July 19, 2006 6:59 am | ||||||||
Mike Blackney
Haha how funny that we both did pretty much the same thing
Yours is more useful, though - it actually lets you get the RGB like the OP asked for. |
| Posted: July 19, 2006 8:49 am | ||||||||
byRo
Which makes it instructive to examine the differences. - Moving the sample to centre, as you did, is a neater solution than moving the sampling point around. - "Blending" using Profile Gradients is a neat trick that I'll have to remember. - Didn't understand the width 1 impulse minus the width 0.5 impulse, though. Rô _________________________________
| Posted: July 19, 2006 10:27 am | ||||||||
byRo
| Posted: July 19, 2006 10:41 am | ||||||||
Mike Blackney
I only just worked that one out myself
Ahhh, change the position of the 0.5 impulse to -49.5 and the width of the 1 impulse to 2. That'll look more like what I wanted to get
Much nicer! |
| Posted: July 19, 2006 5:11 pm | ||||||||
Jason Rodriguez
Posts: 2 |
I was wanting to get pixel values since this program looked like a great/easy way to test out different debayer algorithms (a Bayer CFA is the color grid that is on single-chip cameras).
Thanks for all the feedback. I'm assuming I can take the color picker values from your graphs and then plug that as the values I would need to calculate the values for the demosaic algorithm . . . of course I would also need a FOR loop or something of that nature to get the picker to keep shifting down the image-not so sure that's possible . . . I haven't looked at the documentation yet, sorry if these are silly questions. |
| Posted: July 20, 2006 11:27 am | ||||||||
