As I have told already here I like much the new website
I have found until now 2 errors (the second is on the post below) 1 - THUMBNAIL IN FILTER COMMENTS POSTS STILL BAD In the old website it was already told that this was bad Thumbnail used in filter comments and that thumbnails that are shown on the page created for filter comments show them in very low blurry resolution compared to the one that is shown on the filter page One of the first things I tried after seeing that the filters thumbnails page are now bigger and sharper is to see if the thumbnails in the forum has been solved, but disappointedly this is still not fixed and now the error is still more obvious the difference between the main one and the forum page as seen below Sorry that I do not know anything about how is programmed and made the website, but I do not know why this could not be fixed and is still the same in the NEW website. Is a pity that with the new great looking new website thumbnails the forum thumbnails look so bad. |
| Posted: December 23, 2020 1:27 pm | ||
| Posted: December 23, 2020 1:38 pm | ||
2 - MORE SMILEYS does not work
When you click on the "More smileys" link it opens a new window but when you click on any of the smileys only shows a text about javascript but the smiley is not shown on the text of the forum As now the post space to write is bigger wouldn´t it be better to put them all on main screen instead of having to open a window? Also If you open the smileys window, and forget to close it, it goes behind the window you are using for the FF website and if you click on the "More smileys" link again, nothing happens, and is because the window is already open but you do not know it, and think is not working, and is because is already open. |
| Posted: December 23, 2020 1:47 pm | ||
Now Rachel Duim has also posted about the same first problem as seen here
with the new shiny and great website is a real pity that in the main thumbnail looks bigger, better and sharper and the forum one looks so bad in comparison |
| Posted: December 23, 2020 2:34 pm | ||
11 unregistered users.
