JesusSheep
Posts: 87 |
Update broke filter forge 6 as well.
| Posted: June 25, 2016 8:23 pm | ||||
FilterForge wrote days earlier that a fix is coming our way so hold on tight!
| Posted: June 25, 2016 9:56 pm | ||||
JesusSheep
Posts: 87 |
Last I saw the update was for 5 not 6.
| Posted: June 25, 2016 10:03 pm | ||||
You should read more carefully:
From this thread: https://filterforge.com/forum/read.php?FID=5&TID=14242
| Posted: June 25, 2016 10:04 pm | ||||
JesusSheep
Posts: 87 |
I Stand corrected good to hear.
How would Stress test Filterforge 6? |
| Posted: June 26, 2016 10:33 am | ||||
In terms of it, I think you can just render giant images. However, the real stress test is to use it in your normal workflow. You likely have a chance running into a bug by just using it regularly.
| Posted: June 26, 2016 7:58 pm | ||||
Posts: 3507 |
If you install a host application that was released later than your FF version, you can expect the plugin to fail.
Support for CC2015.5 will appear in the beta version a bit later, together with the ability to download filters. |
| Posted: June 28, 2016 11:05 am | ||||
15 unregistered users.
