Zep Palen
Filters: 10
In the Forum Thread Filter Forge - Rotate Image there is a link to: Rotate All Angles.
I donwloaded it to my FF 4.
When I try to edit (clicking "Filter Editor") this with FF 4.007 FF is crashing. and I get the following error message: "<class XFW::StateError> Unable to find viewport info of the group ''".
Doing the same in FF 3 works fine with no crashing.
Zep Palen, what computer are you using and what Windows or MacOs version?
I am using Windows 8.0 64 bit and FF 4.0.7
Yes! I have tested it also in both FF 3.0 and FF 4.0, and is true that in FF 3.0 there is no problem to use and edit it and in FF 4.0 in the same moment that you try to open it, crashes FF 4.0.7 and you get the error message: "<class XFW::StateError> Unable to find viewport info of the group"
Here below is the beginning of the bug report I have got
Code
Operating system:  x64 Edition (6.2 build 9200)
Physical memory: 16301 MB
Number of processors: 8, available: 8
Processor info: Intel® Core™ i7-2600K CPU @ 3.40GHz, ~3389 MHz
Filter Forge x86 4.007.30696.35474 Release, December 20, 2013 07:57 [23/12/2013 14:29:30 Hora estándar romance]
[Controls::Control] Exception occured while processing window message 0x00000401(WM_USER) (0x00000001 0x01D8C07C) for window 00C71A22/00C71A22, control: <class Controls::Form>@01D8C07C.
[Controls::Control] Exception occured while processing window message 0x00000111(WM_COMMAND) (0x0000C320 0x00611F88) for window 00E5124C/00E5124C, control: <class Controls::Panel>@12C6E768.
[Controls::Control] Exception occured while processing window message 0x00000202(WM_LBUTTONUP) (0x00000000 0x00150020) for window 00611F88/00611F88, control: <class Controls::PushButton>@13BDC320.
Exception caught at thread 0001434C 'Application':
Zep Palen, thanks for your report, this is a bug point for you.
Zep Palen
Filters: 10
I am using Win 7 Pro 64 bit and here is the complete report I get if that is useable here in Forum.
Code
Operating system:  x64 Edition (6.1 build 7601) Service Pack 1
Physical memory: 12278 MB
Number of processors: 2, available: 2
Processor info: AMD Phenom™ II X2 555 Processor, ~3192 MHz
Filter Forge x86 4.007.30696.35474 Release, December 20, 2013 07:57 [23-12-2013 14:43:05 Rom, normaltid]
[Controls::Control] Exception occured while processing window message 0x00000401(WM_USER) (0x00000001 0x01D8C0EC) for window 003214B0/003214B0, control: <class Controls::Form>@01D8C0EC.
[Controls::Control] Exception occured while processing window message 0x00000111(WM_COMMAND) (0x00006FF0 0x000C12CE) for window 001C11E2/001C11E2, control: <class Controls::Panel>@042D6640.
[Controls::Control] Exception occured while processing window message 0x00000202(WM_LBUTTONUP) (0x00000000 0x000E000B) for window 000C12CE/000C12CE, control: <class Controls::PushButton>@05586FF0.
Exception caught at thread 00001FB8 'Application':
<unknown file>(0) : <unknown function>()+0 at 004C242A in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : gapfnScSendMessage()+818 at 75B862FA in C:\Windows\syswow64\USER32.dll
<unknown file>(0) : <unknown function>()+0 at 004C831D in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 004C22BD in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 004BB5F5 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : CtfImeAssociateFocus()+1454 at 75415886 in C:\Windows\syswow64\MSCTF.dll
<unknown file>(0) : <unknown function>()+0 at 005CA47E in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 005CDA4F in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : GetThreadDesktop()+215 at 75B86D3A in C:\Windows\syswow64\USER32.dll
<unknown file>(0) : CharPrevW()+312 at 75B877C4 in C:\Windows\syswow64\USER32.dll
<unknown file>(0) : DispatchMessageW()+15 at 75B8788A in C:\Windows\syswow64\USER32.dll
<unknown file>(0) : <unknown function>()+0 at 005C9133 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
CONTEXT_CONTROL: CS:EIP 0023:7616C41F, SS:ESP 002B:01D8ABF0, EBP 01D8AC40, FLAGS 00200216
CONTEXT_INTEGER: EAX 01D8ABF0, EBX 01D8ACA4, ECX 00000003, EDX 00000000, ESI 00B740E4, EDI 01D8AC80
Zep Palen
Filters: 10
GMM thank you.
Where do I see my points? And what is the difference on bug points and filter points?
Zep, you have one point for reporting this particular issue (btw, the fix will be available as a silent update this week).
It is not related to filters gaining the high usage status: it was a campaign to foster submissions of bug reports for the beta version of Filter Forge 4.0. This bug hunting campaign ended yesterday.
Zep Palen
Filters: 10
Ok. I probably just dont understand what the points can be used for from bug reporting.
So I guess my question should be: "Can those points be used for anything like we can for filter usage points?"
Zep Palen: unfortunately no. If you had reported three or more qualifying bugs you could have won a free license but you arrived too late for that.
I think FF5 will have a bug hunting campaign on the same terms, and you will be able to join in.
11 unregistered users.
