Admar
A007
I purchased the Basic version to see how it would work. But the Plugins only support until CS 5.1
I have the latest version of CS, which is 2015.
Can anybody of you, please help me and tell me what to do
Thank you very much
Best Regards
Adrianus
A
Filter Forge supports CC2015. What error message do you get?
Please also look at the older forum threads.
Admar
A007
Dear Moderator,
Thank you for your answer.
FF only works from their stand alone program, which is very slow.
In PS CS, it does not show anything under the Filters
When I run the Installation of the Filter, I get the following message:
Searching for Adobe Photoshop CS2...
Adobe Photoshop CS2 found at /Applications/Adobe Photoshop CC 2015/.
ln: /Applications/Adobe Photoshop CC 2015/Plug-Ins/Filters/FilterForge.pluginv4/Filter Forge 4 ppc.plugin: Permission denied
Failed to install Filter Forge plugin for Adobe Photoshop CS2.
Searching for Adobe Photoshop CS3...
Adobe Photoshop CS3 found at /Applications/Adobe Photoshop CC 2015/.
ln: /Applications/Adobe Photoshop CC 2015/Plug-Ins/Filters/FilterForge.pluginv4/Filter Forge 4 universal.plugin: Permission denied
Failed to install Filter Forge plugin for Adobe Photoshop CS3.
Searching for Adobe Photoshop CS4...
Adobe Photoshop CS4 found at /Applications/Adobe Photoshop CC 2015/.
Failed to install Filter Forge plugin for Adobe Photoshop CS4.
Searching for Adobe Photoshop CS5...
Adobe Photoshop CS5 found at /Applications/Adobe Photoshop CC 2015/.
ln: /Applications/Adobe Photoshop CC 2015/Plug-Ins/Filters/FilterForge.pluginv4/Filter Forge 4 universal x86.plugin: Permission denied
Failed to install Filter Forge plugin for Adobe Photoshop CS5.
Searching for Adobe Photoshop CS5.1...
Adobe Photoshop CS5.1 found at /Applications/Adobe Photoshop CC 2015/.
Failed to install Filter Forge plugin for Adobe Photoshop CS5.1.
logout
[Process completed]
I add two screenshots
A
Admar
A007
This is the second screenshot
A
Admar
A007
I have found an old posting, and have executed that command, the installation was done successfully, but still nothing to be usable in PS. The Effects maybe are nice, but the Instalation is like a Amateur Club, who has to figger out the problems all the Customers together in a Forum.
I am glad I did not buy the whole package.
sudo ./InstallPlugins
WARNING: Improper use of the sudo command could lead to data loss
or the deletion of important system files. Please double-check your
typing when using sudo. Type "man sudo" for more information.
To proceed, enter your password, or type Ctrl-C to abort.
Password:
Searching for Adobe Photoshop CC 2015...
Adobe Photoshop CC 2015 found at /Applications/Adobe Photoshop CC 2015/.
Filter Forge plugin installed successfully.
Searching for Adobe Photoshop CC 2014...
Adobe Photoshop CC 2014 found at /Applications/Adobe Photoshop CC 2015/.
Searching for Adobe Photoshop CS6...
Adobe Photoshop CS6 found at /Applications/Adobe Photoshop CC 2015/.
A
Judging from the first screenshot I assume the plugin has been installed successfully.
Filter Forge is not slow, though certain filters may be slow. Here is a thread with hints to reduce rendering times.
18 unregistered users.
