Hudsonhawk
Posts: 2 |
I'm using a mac running OS 10.8.5 Filter Forge 4 will open in PS CS6, but will not open In PS CC. I had the same issue during the the beta testing. I just uninstalled and reinstalled FF 4, but it still will not open in CC. Any ideas?
Thanks |
| Posted: November 29, 2013 11:40 pm | ||||
Hudsonhawk
Posts: 2 |
Never mind, got it.
| Posted: November 29, 2013 11:53 pm | ||||
Goldgraeber
Posts: 3 |
Hi Hudsonhawk, same problem (running Mavericks) but no solution. Could you share yours?
| Posted: December 20, 2013 12:03 pm | ||||
Posts: 3507 |
Goldgraeber, does Filter Forge work correctly for you in the standalone mode?
| Posted: December 23, 2013 6:00 am | ||||
Goldgraeber
Posts: 3 |
Hi,
yes it opens standalone, and it opens in CS6 version. It does not show up in CC. BTW: the system also has Nik (Google) Efex installed. Because this has been reported as a source of coexistence problems, I have temporarily removed the Google folder from plugins, but that did not make any change |
| Posted: December 24, 2013 3:03 am | ||||
Posts: 3507 |
Please download and reinstall the latest version from the download page.
If Filter Forge still fails to install as a plugin, please launch Terminal from Spotlight or Launchpad > Utilities and type this: cd /Applications/Filter\ Forge\ 4/ sudo ./InstallPlugins Sudo will ask you for an admin password, as InstallPlugins requires elevated privileges. |
| Posted: December 24, 2013 6:40 am | ||||
Goldgraeber
Posts: 3 |
Hi,
this did not solve the problem either (and, in fact, the previous version had "installed", since a Filter folder with the plugin had appeared inside Plugins folder. However, the manual install (and seeing some messages) helped: First of all, it complained about ln not permitted ..., and the plugin file was not updated. Next, I explicitly removed the plugin and ran the manual install again - new file, another complaint about ln, and still not working. ls -l on the plugin showed that it was linked to the ppc version. Here I tried ln -sf to replace the link, but ln complained. Removing the previous link and then linking worked (Is there no ln -sf on a Mac, or did Mavericks add some constraints?) Now the x86 version of plugin works perfect. I did not look at the install script, but ln complaining about permissions while a new file actually gets there looks weird - is install trying the symlink more than once? |
| Posted: December 25, 2013 2:35 am | ||||
Hitch
Posts: 5 |
Hi,
I am having the same problem with getting FF to run on Photoshop CC on my Mac running Lion 10.8.5. I can get it to recognize FF (it shows under filters) but when I try to open it I get the message "Could not complete the Filter Forge 4 command because of a program error". I didn't sign up for this and will need to contest the charge if there is no fix. |
| Posted: January 20, 2014 12:45 pm | ||||
Hitch
Posts: 5 |
I tried the Moderators fix (running: cd /Applications/Filter\ Forge\ 4/
sudo ./InstallPlugins) and got the following response: Searching for Adobe Photoshop CC... Adobe Photoshop CC found at /Applications/Adobe Photoshop CC/. ln: /Applications/Adobe Photoshop CC/Plug-Ins/Filters/FilterForge.pluginv4/: Operation not permitted Failed to install Filter Forge plugin for Adobe Photoshop CC. any other suggestions? |
| Posted: January 20, 2014 1:01 pm | ||||
Posts: 3507 |
Hitch, this means the plugins were physically installed but for some reason Photoshop fails to recognize them.
Please locate this file: /Applications/Adobe Photoshop CC/Plug-Ins/Filters/FilterForge.pluginv4 delete this file and then run InstallPlugins again: open Terminal and type this: cd /Applications/Filter\ Forge\ 4/ sudo ./InstallPlugins InstallPlugins should report that "plugin installed successfully". Run PS CC and check if it helped. |
| Posted: January 21, 2014 6:29 am | ||||
JennR
Posts: 2 |
Hi, I'm having exactly the same problem as Hitch. I'm on a Mac (brand new Maverick OS), running the latest version of PS CC, and I just downloaded FilterForge 4. I did exactly as you just described and got the same error as before:
Searching for Adobe Photoshop CC... Adobe Photoshop CC found at /Applications/Adobe Photoshop CC/. ln: /Applications/Adobe Photoshop CC/Plug-Ins/Filters/FilterForge.pluginv4/: Operation not permitted Failed to install Filter Forge plugin for Adobe Photoshop CC. Is there something else we can try? Thanks, Jenn |
| Posted: January 28, 2014 9:05 pm | ||||
JennR
Posts: 2 |
Addendum: I downloaded and installed FreePack3 - Frames and suddenly now all the plug-ins are working. Weird, but yay!
Jenn |
| Posted: January 28, 2014 9:35 pm | ||||
Hitch
Posts: 5 |
I am still having no luck getting PS CC to recognize FF4. I have tried the above suggestion and get this message:
Searching for Adobe Photoshop CC... Adobe Photoshop CC found at /Applications/Adobe Photoshop CC/. ln: /Applications/Adobe Photoshop CC/Plug-Ins/Filters/FilterForge.pluginv4/: Operation not permitted Failed to install Filter Forge plugin for Adobe Photoshop CC. How can I uninstall FF4 so I can do a clean install? |
| Posted: January 30, 2014 3:31 pm | ||||
mrcricket
Posts: 1 |
I am having the exact same issue. Tried running the script in Terminal and get this reply:
Searching for Adobe Photoshop CC... Adobe Photoshop CC found at /Applications/Adobe Photoshop CC/. ln: /Applications/Adobe Photoshop CC/Plug-Ins/Filters/FilterForge.pluginv4/: Operation not permitted Failed to install Filter Forge plugin for Adobe Photoshop CC. Please help. I'm on a deadline and need Filter Forge to help me make it. Jonathan |
| Posted: February 3, 2014 12:08 pm | ||||
Posts: 3507 |
Please delete the /Applications/Adobe Photoshop CC/Plug-Ins/Filters/FilterForge.pluginv4 file and copy the entire "Filter Forge 4" folder from /Applications/ to /Applications/Adobe Photoshop CC/Plug-Ins/Filters.
| Posted: February 4, 2014 5:00 am | ||||
Hitch
Posts: 5 |
OK, THAT DID IT!!!
Copying the entire FF app into PS CC plugin folder made the difference. It all seems to work as advertised. Thank you GMM for sticking with it! |
| Posted: February 8, 2014 1:15 pm | ||||
catinaround
Posts: 8 |
I can't run FF4 inside of Photoshop and it won't render outside of Photoshop. I took a screenshot of what shows in my Plug-ins folder for Photoshop (CS5). What should I delete in order to do the install GMM mentions above? (I don't want to delete something in error.)
| Posted: March 2, 2014 5:46 pm | ||||
bethrosengard
Posts: 24 |
I just had the same problem as Hitch and it was solved with the same solution given by GMM. Thanks guys!
Beth |
| Posted: March 2, 2014 8:22 pm | ||||
| shiftstudio |
This way worked for me too - although I see it as kind of a workaround solution... --shift studio. |
| Posted: March 11, 2014 11:57 am | ||||
hitchfilter
Posts: 5 |
Another point that some may not realize is that FF will not open or load a PSD file. I believe the formats that are compatible include: JPEG, PNG, TIFF, OpenEXR, TGA and PFM. There may be others, but I could not find an all inclusive list anywhere in FF4. If you try to open FF4 to apply a filter to a .PSD file I get a program error message.
| Posted: March 11, 2014 2:45 pm | ||||
Heres the list when opening an image in FF....
![]() Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: March 11, 2014 4:32 pm | ||||
Prot
Posts: 1 |
Got the same problem.
1- Filter Forge 4 folder (in Applications) has a permission problem -> copy all files inside this folder into a new folder in "Applications" - Delete the old folder and rename the new one Filter Forge 4. 2- Delete "FilterForge.pluginv4" in Photoshop/plugins/filters (it leads to the PPC plugin, that's why it does not work properly) 3- You have to create a symbolic link for "Filter Forge 4 universal x86.plugin". To do that: download the really useful app: SymbolicLinker and copy the file "SymbolicLinker.service" into /Library/Services/ In "Filter Forge 4" folder -> right clic on "Filter Forge 4 universal x86.plugin" > Services > Make Symbolic Link It creates a symbolic link "Filter Forge 4 universal x86.plugin symlink" Move this file into photoshop > plug-ins > filters folder and rename it "FilterForge.pluginv4" Now it works with CC and mavericks |
| Posted: May 5, 2014 4:34 pm | ||||
Posts: 3507 |
Yes, the above method works. Instead of a symlink you can create an alias for the Filter Forge 4 universal x86.plugin file by Alt+Cmd+dragging it to the target location.
| Posted: May 6, 2014 9:46 am | ||||
Beth Rosengard
Posts: 24 |
iMac OS 10.8.5; PS CC 2014 (also PS CS6); FF 4.011 (also FF 3)
I was having all kinds of trouble getting FF 4.011 to open in PS CC. It kept opening 4.010 and telling me I needed to download and install the new version – which I'd already done. After trying all kinds of things, I finally decided to trash all versions of FF 4 and start from scratch. I did a system-wide search for FF and delete all instances of FF 4, regardless of version (I left FF 3, which I still have and which works fine). I re-downloaded FF 4.011, installed it and opened it successfully from within PS but … there are NO filters at all. I checked Applications—FF 4—Resources—System—Library and it's full of filters. So why does the app tell me I don't have any? Apparently it doesn't "see" those filters. How do I fix that? Note: I already tried dragging an alias of the entire FF 4 folder from Applications to the PS CC Plug-ins—Filters folder. TIA, Beth |
| Posted: October 6, 2014 9:00 pm | ||||
Beth Rosengard
Posts: 24 |
Never mind! I decided to upload a new filter from the online gallery and when FF uploaded that filter, it also uploaded my entire filter library! I don't get it, but I'm glad it's straightened out
| Posted: October 6, 2014 9:07 pm | ||||
| Novaesky |
I recently got a new computer at work and am now using Adobe Photoshop CC 2015, but I'm having trouble getting filter forge to work inside Photoshop. I tried copying the Filter Forge 4 folder over into the Plug-ins folder, but that didn't work, neither did just copying over the contents of the x64 folder.
These are fresh installs of both programs, and as far as I understand, Filter Forge should auto-detect Photoshop CC, but it doesn't seem to. Please help. Thanks in advance. -Daniel |
| Posted: June 16, 2015 11:18 am | ||||
Posts: 3507 |
Daniel, you can use Filter Forge as a plugin in any supported host application or as a standalone program.
| Posted: June 17, 2015 5:23 am | ||||
| Novaesky |
Alright, so I see CC 2015 isn't on that list. Are there any plans to add support for it? I realize I can use FF as a standalone program, but the plugin was very convenient.
| Posted: June 17, 2015 7:19 am | ||||
Posts: 3507 |
Yes, support for CC 2015 will be added in the next program update.
| Posted: June 17, 2015 8:00 am | ||||
olsh
Posts: 3 |
Downloaded the latest versions of FF4 and FF5. None shows up in the PS CC 2015 menu (OSX 10.10.4). The apps run only in the stand alone mode.
Please advise! It's been so frustrating! I bought ver 4 in the spring and prepaid for ver 5. |
| Posted: July 27, 2015 11:39 am | ||||
Posts: 3507 |
olsh, you can install the plugin manually:
| Posted: July 27, 2015 12:13 pm | ||||
olsh
Posts: 3 |
Followed the instructions. That's the log Searching for Adobe Photoshop CC 2014...
Adobe Photoshop CC 2014 found at /Applications/Adobe Photoshop CC 2015/. Filter Forge plugin installed successfully. Searching for Adobe Photoshop CS6... Adobe Photoshop CS6 found at /Applications/Adobe Photoshop CC 2015/. Filter Forge plugin installed successfully. Searching for Adobe Photoshop CS2... Adobe Photoshop CS2 found at /Applications/Adobe Photoshop CC 2015/. Filter Forge plugin installed successfully. Searching for Adobe Photoshop CS3... Adobe Photoshop CS3 found at /Applications/Adobe Photoshop CC 2015/. Filter Forge plugin installed successfully. Searching for Adobe Photoshop CS4... Adobe Photoshop CS4 found at /Applications/Adobe Photoshop CC 2015/. Filter Forge plugin installed successfully. Searching for Adobe Photoshop CS5... Adobe Photoshop CS5 found at /Applications/Adobe Photoshop CC 2015/. Filter Forge plugin installed successfully. Searching for Adobe Photoshop CS5.1... Adobe Photoshop CS5.1 found at /Applications/Adobe Photoshop CC 2015/. Filter Forge plugin installed successfully. Dmitriys-iMac:Filter Forge 4 DOImac$ The FF is still missing from the filters menu |
| Posted: July 27, 2015 1:50 pm | ||||
Posts: 3507 |
That's strange indeed. Usually this issue is caused by some kind of permission problems where InstallPlugins is unable to register the shortcut... but this is not your case. Please try the following:
- delete the /Applications/Adobe Photoshop CC 2015/Plug-Ins/Filters/FilterForge.pluginv4 file and copy the entire "Filter Forge 4" folder from /Applications/ to /Applications/Adobe Photoshop CC/Plug-Ins/Filters. In Photoshop, go to Preferences > Plug-ins, click Additional Plug-ins Folder and point to the Filter Forge 4 folder in Applications. It should make Filter Forge 4 appear in the plug-in list. |
| Posted: July 28, 2015 8:08 am | ||||
olsh
Posts: 3 |
Miracle happened!
While at it - can I test FF5 or it can screw the set up I have working now? Thank you! |
| Posted: July 28, 2015 10:47 am | ||||
Posts: 3507 |
Did they remove the ability to specify an additional plugins folder? You should complain on Adobe forums about that
You can definitely test FF5, it won't affect your current installation. Treat FF4 and FF5beta as separate programs. |
| Posted: July 28, 2015 11:36 am | ||||
Unhappy former user
Posts: 9 |
I installed FF4 with Photoshop CC 2015. It appears in the filter list, but will not work -- I only get a spinning beach ball until I close FF. I tried the remedy above -- "delete the /Applications/Adobe Photoshop CC/Plug-Ins/Filters/FilterForge.pluginv4 file and copy the entire "Filter Forge 4" folder from /Applications/ to /Applications/Adobe Photoshop CC/Plug-Ins/Filters." The only difference that's made is that, along with the spinning beach ball and unusable plugin, I also now get the error message "Could not complete the Filter Forge 4 command because of a problem with the filter module interface."
Any idea how to get it to work without spending half the week trying? |
| Posted: September 18, 2015 2:29 am | ||||
Unhappy former user
Posts: 9 |
Well... that's a mystery. I tried it one more time, and suddenly it worked. I still don't feel good about it. FF3 did this sort of thing all the time -- half the time, I could not get it to work as intended, even when nothing had changed. I feel like a sucker for "upgrading." But thanks for your time here.
| Posted: September 18, 2015 2:34 am | ||||
Miss Fancy Pants
Posts: 7 |
Thanks GMM. this was exactly what our tech needed to get us running. The stand alone was fine but the drop down was initially greyed out. This method also worked for the PC user in our department. I thought you may want to know.
Miss Fancy Pants |
| Posted: March 8, 2016 6:04 pm | ||||
Jibbils
Posts: 1 |
Yeah its not working AT ALL with the newest Photoshop (2017) CC on my laptop but does on my stationary...i dont get it. The only difference is OS, i run win 7 on stationary and win 10 on laptop. Any fix on the horizon? |
| Posted: July 27, 2017 11:08 pm | ||||
12 unregistered users.
