Mike's Favourite Noise by Mike Blackney
http://www.filterforge.com/filters/4516.html
Mike, wouldn't it be easier to use something like this? (see the attached filter). It uses 3 Perlins as well, but their Roughness on average is lower, so it should render faster, plus there's no HSB Extract/hues involved, which is good for avoiding problems with bump map continuity.
Mikexqs Favourite Noise 2.ffxml
Mike Blackney
Filters: 57
That's absolutely the type of filter I'd use for most situations, especially as part of another filter or part of a heightmap. This noise filter is more for using when combined with traditional texturing and you want a noise that surprises you (that's why the extract is great -- the instant black-to-white contrast). It's still sort of fast, but I think the tradeoff in irregularity for time can sometimes be worth it.
This is a specularity map I made using the default presets of mine and your faster version. (The original is on the left.) They're both pretty similar, but I think there's a little more of that natural decay to the slower version.
looks like to me both versions would be useful. vlad's has more of a lower contrast and blur to it, giving a softer decay in your example pic, while mike's has a bit more contrast giving more of that grainy rust feel.
ronjonnie
Designer / Artist
Filters: 320
Hi Mike, smile:)
I wanted to thank you for the use of your cool snippet, I used it in my new Sci-Fi Stone Metal filter I posted 2-18-09. It works great. I used it in Selector 2.
Great work! smile:) smile:)
I will have to check out what Vladimir Golovin sent you, I did not see that.
So much to learn , so little time..
Thanks again. God bless you.
Ron
3dsBlend
3dsBlend
Filters: 38
Very nice! I based one of my filters in honor of it, with not 3...but 27 different perlins! This is truly great!
Haloo! Enjoy this page while you're here! xD
dactilardesign
Filters: 56
Really nice Mike.
"did you see that? but you knew that already because you are an advanced user"
