Edward's Wallpaper by Mike Blackney
http://www.filterforge.com/filters/4327.html
Nice work! A couple of suggestions:
1. An option for transparency would be great.
2. Finer control over the peeling areas (coverage, density etc).
ahimsa
Filters: 41
This is really good. smile:)
Rawn (RawArt)
Texture Artist
Filters: 105
Looks great, I downloaded it immediatly (as i do any distressed texture)
If I can offer a suggestion to, I would love to see optional top or bottom distressing. That would make it easier to use for texturing....and maybe an option to turn the torn effect off, just so one could get a blank wallpaper tile to help fill out the texture sets.
Rawn
i like this idea, but i see at least two things that would keep me from using it, currently. in at least variations #2 and 3 it appears the aging is floating above the paper. and two, the high distressing seems to appear at only the top and bottom of the overall image and that's in every variation.
i love the little fine crackling; that seems to work perfectly, but the dark, larger areas need some work.
now, since someone else mentioned this, my remarks on the high distress areas are ONLY based on looking at what's on the web page here. i havent looked at the filter itself and i'm told there can be quite a difference. so, if the filter itself isnt showing that floating, then just ignore that part.
Mike Blackney
Filters: 57
Thanks, everyone. Very good points on all counts, I'll see what I can cook up smile:D
Foxxee
Filters: 61
Very nice indeed!
Looking forward to what your revision will offer too, Mike smile;)
~Foxxee~
ahimsa
Filters: 41
Congratulations on becoming Editor's Pick! smile:banana: smile:beer:
Mike Blackney
Filters: 57
Goodness! That was unexpected!
Thanks, Ahimsa smile:)
Here's what it looks like in Unreal Engine 3:
ahimsa
Filters: 41
That looks really good and run down. smile:D
When I got mine it was very unexpected. I'm still amazed that one of mine actually got EP. smile:D
onnetz
congrats.. man your just crankn em out.. smile:-)
Try to lower Surface Height (on the Lighting tab) to 5 or 10 instead of 20 before generating normal maps -- this will make the peeling more realistic.
Mike Blackney
Filters: 57
That's a good idea. I rendered using a height of 20 and then did a 50% blend with a normal map I generated from the diffuse, but I think I fell for the old trap of wanting to show off all the detail I'd put in at the cost of realism and it... erm... looking nice smile:eek: smile:D
11 unregistered users.
