Messages 1 - 45 of 118
First | Prev. | 1 2 3 | Next | Last
Rawn (RawArt)
Texture Artist
Filters: 105
Rawn (RawArt)
Texture Artist
Filters: 105
This looks great!
My only comment for improvement would be to add some rust stains (and streaks that run down the concrete some) around the metal bars smile;)
Well done though...just my kinda thing
Rawn
Looking good there!
I'm with Rawn: Give us some grit and grime and weathering. smile:D
And the steel reinforcements could look a look more rusty, maybe like the rust on this one.
Just my 1,618 cents... smile;)
Capt'n Cheeky smile:dgrin: This is totally awesome work!!! It does look very realistic for newly poured cement over freshly wheelabrated rebar that has not been weathered. See, no one can say that I'm not a "cup is half full" kinda guy smile;) smile:D LOL....
I agree with Rawn and Dilla's suggestion to incorporate rusty bar range of texture on this one.....or just make a second version that does it.....
Presidio
Presidio
Filters: 43
Looks Good~~~!!!!
Grabbing it now~ smile:D smile:D smile:D smile:D
oh wow! you did damaged concrete! the gamers will love you! excellent filter!
Redcap
Redcap
Filters: 100
Carl, you are the man.
Got to complement you on 2 things
1)you put yellow color into the concrete, that is so true to life. Just the other day I was asking my wife what caused the rust color and she thought I was a wacko, I was asking because I was thinking of making a filter smile:D Who besides Filter Forgers notice small details like that, good job.
2)Best concrete look to date, seriously.
Having worked with concrete one summer I have to agree with Crapadilla's suggestion, rebar is rusty before it goes into the concrete, so a way to effect the steel rust level may be nice; however, with that said after concrete dries and then is broken of the rebard it usually paints the rebar grey matching the concrete.
Also rebar is ... how can I explain it??? Grooved... I don't know if that explains it, here is a picture http://en.wikipedia.org/wiki/Image:Trebar.jpg
So if you could make it groved that would be more photo-realistic as well, good job.
actually, it's ribbed. this is to give it more surface area to hold the concrete better. a straight cylinder would tend to slip more within the concrete.
Partially correct smile;) smile:D .....shallow crossing spirals.....don't use straight ribs because creates fracture/break points.....I was a steel fitter for many years smile:)
ah, there ya go smile:)
LOL.... actually, now that I think about it, some sill tie rods are smooth with welded bolts or just L-curved on the ends to hold them in the cement.....so I was partially.....wr....wro....wrong smile;) smile:D Getting harder to admit that in my old age smile:D
Excellent, I'm working on it but not happy with it yet
more rusty
It's got colour control over Reo - I'll change some of the presets to have rustyer look
Your spot on suggestion - thanks again smile:)
Just my 1,618 cents
Thats fifty dollars Australian so your opinons are worth even more here smile:D
wheelabrated
Love the word, have to incorporate it in filter blurb even if I haven't got a clue what it is LOL smile:D
Taken suggestion have altered, posting examples after this short story I seem to be typing smile:)
Persidio wrote:
Grabbing it now
Ahh music to my ears smile:D
All excellent comments and suggestion - thankyou all - will be working on all improvement - posting 2 samples pic with Reo one showing rusty version also including a shadow from the Reo - as I say still working on griming it up - I may have a problem though, its a complex render and it taking 12 odd minutes to render the more textured ones - ff police will lock me up if it takes this or any more time smile:?: Anyway here they are
Rawn (RawArt)
Texture Artist
Filters: 105
Looking great smile:)
some rust stains on the concrete itself and you are sold smile:D
awesome work
Rawn
That last one is looking really good smile:) If you want it even more realistic....criss-cross the spriral ribs, make them less pronounced (just barely see them, and add some rust stains on the cement from the rusting rebar....
If I have interpretted the "Editor's Pick" formula correct, this should definitely become one!!! smile:) Vlad won't even make a comment on any of mine.....let alone consider one as an Editor's Pick.....I'm starting to get a complex about it smile:| smile:cry: smile:dgrin: LOL.... J/K.....I just don't do the type of filters like this that he likes smile:)
i wouldnt worry too much about the rust running on the concrete. but, if you can do it, well good. we'll just call this one, newly damaged concrete.
i'm a little concerned with the rebar criss-cross. can you spread it out more and is that built in as a control?
i'd be more concerned, though, with the render time. 12 minutes is a fairly long render for a single texture. but, if you have to lose any of this excellent effect over the time issue, forget it. keep the 12 minutes and the quality smile:) i'll take a look at this one's guts and see if i can offer any suggestions on the time thing.
Good idea.....two versions....old and new damaged concrete.....
another good idea smile:)
Yeah, this definitely looks like an "Uber Challenge" to me.....any chance of getting him out of retirement??? smile;) smile:D LOL..... smile:)
render time on my machine = 8 min. 50 seconds.
ok, i see at least three things where you might be able to speed this up. you've got two high passes and a cells. the cells shld be replaceable with a perlin. there's nothing that special you're doing with the cells that the perlin cant do.
the high passes may be a different matter, though. still looking....
ok, by removing just that one cells component i got it down to 4 minutes, 51 seconds and i dont think i lost any quality in doing so. i'm posting the filter here. if you use it make sure you change yourself back as the author. also, by removing the cells it changed all the presets so you might have to redo those as well.
i havent fooled with the high passes yet. maybe tomorrow, but have a look at them and see if they cant be replaced with something else.
oh, and even if i did damage the quality, i think you can see how to fix it. this was more or less a cursory look and a quick fix. so, play around with it.
Damaged Concrete rev 1.ffxml
Good thinking on swapping out the Cells Component..... I just popped the hood of it.....and you can see that it is hanging up on the high pass.....
Mike Blackney
Filters: 57
Hey, I just saw this one. Wonderful work!
Thanks Mike, good to see you back smile:)
Kraellin thanks for help so far { hint still needs your input } I hadn't realized how the cell would almost double the time for rendering - I'd put it in to stop a flattening which occurs under the reo when large areas are exposed [ more obvious when tiling is switched on ] I know it must be acheivable wiht fine tuning so are still fiddling with your help - thanks again I think that I'm going to have make this a joint filter smile;) smile:)
nah, dont have to make it a joint filter, or, if you think you must, then credit vladimir for his letting us know which components are 'fast' and which arent smile:)
and what is 'reo'? is that a shortened word for rebar?
Reo what it's called here - if you follow redcaps link to the wiki [ which also calls it Trebar ] then on to the meaning it mentions the aussie word Reo , I was glad he put the link in cause I spelt it Rio LOL smile:)
ah, ok. thanks smile:)
Revelation
Filters: 14
Carl...
Amazing filter! Very nice work!
A couple of suggestions for the finished product:
Rebar doesn't actually weave in and out. Typically, the workers will place a layer of bars parallel to each other, then place a layer perpendicular to the first. The intersections are then tied together with wire. I don't think the wire ties are necessary in your filter, but is it possible to simply show one horizontal layer laying perpendicular to a vertical layer underneath? Also, maybe allow for a bit more spacing. Typically, 6" centers are fairly common.
Also, is it possible to add a bit of aggregate to the broken sections? A bit of color, a bit of rust stains like others have mentioned?
I am not being critical at all. This is an extremely nice, useful and thought out filter. I can't create it myself...only adding suggestions and comments.
Very nice smile:)
+2 again smile:D
adjusted smile:)
more adjustable
adjustable grime etc now included
I've also added cross ribbing on Reo and rusted the bars, and a switches allow plain concrete / plain damaged concrete / plain damaged concrete with Reo
Thanks everyone for the suggestion / encouragement, I've found a few annoying bugs which occur with the random which I can't get rid of things that really shouldn't be effected. It would also be great to have a greater depth to play with. I've basicly gone mad trying to get this to work properly going between over complicating to loosing the essence. I still have to make new presets etc, and after all this I should have run this through the Users Gallery first, and I'd love to acheive more but the time is a limiter, Kraellin if I could ask more of you, I'm resubmitting for tomorrow if you could have another peek and make any more time saving ideas I would greatly appreciate you'll notice I've reconstructed hugely including get rid of the cells as you suggested.......... my brain a fury blob from this seemingly simple task of a lump of concrete - all the suggest have been great thanks again everyone....... adding one new pic smile:)
well, i think it looks great. you even shadowed the rebar/reo.
well, i dont know if you wanted me to look at your current incarnation and if so, i'd have to have the filter. from the earlier version, what i said still stands, cells and 2 high passes. if you absolutely have to have the 2 high passes, then see if you cant remap them to keep the contrast and radius as small as possible and still get the desired effect. the greater values of those two, the slower things will get.
Revelation
Filters: 14
Carl....you nailed it! Perfect! I'll be using this filter frequently smile:)
Nice job!
got rid of cells but could seem to get rib of H/passes
I'll have more of a fiddle, it really got to the stage of frustration - I kind of never want to hear the word CONCRETE again LOL smile:)
Revelation wrote:
you nailed it!
Thankyou for your suggestion - I would have liked the aggregate, and more depth [ the program has a limit before it flattens out] and to be much faster - loosing the cell saved alot of time but caused other problems.
Again thanks everyone !! smile:)
ronviers
lighter/generalist
Carl you have turned this into an excellent filter. It really looks like reinforced concrete. I bet we will see this one in a game. smile:)
@ronviers
Rawn (RawArt)
Texture Artist
Filters: 105
Brilliant!
This is definatly one of my favorites
ahimsa
Filters: 41
Has this been updated to where I can download it again?
Oh, and it is very, very tough and rugged! smile:D
Count Von Cheek!!! smile:dgrin: Upgrade looks really good!!! I don't care what anyone says about you.....it's all true!!! smile:dgrin: smile:dgrin: smile:dgrin: LOL....
LOL.... Where's that Navy Seal smilie??? smile:D
ronviers
lighter/generalist
Did I miss something here? Has the butchness of Carl's filter been called into question? smile;)
Hmm, maybe I should get to work on a flannel filter…
@ronviers
Yeah, I'm not buying the "tough and rugged" thing.....I think this filter is a clever ploy to cover up his true desire to make pastel needlepoint and crochet filters smile:dgrin: smile:dgrin: smile:dgrin: LOL..... smile:)
ronviers
lighter/generalist
Yes, things like hearts, eggs, metallic pastels, suds and bubbles … wait a minute smile:blush:
@ronviers
Foxxee
Filters: 61
So, this filter now has a drop-shadow in it from the wire grids?
If so then I'll download it, it looks 110% better than before smile;)
~Foxxee~
Foxxee
Filters: 61
ronviers wrote:
Quote his true desire to make pastel needlepoint and crochet filters
Yes, things like hearts, eggs, metallic pastels, suds and bubbles … wait a minute Blush
Heheh, just saw this one after I posted smile:-p
Well, there goes another one, girls... poor Ron smile;)
~Foxxee~
ahimsa
Filters: 41
Don't know...how about this instead?
ahimsa
Filters: 41
Operation Flower Power is going quite well. smile:dgrin:
ronviers wrote:
excellent filter
Brilliant!
I think this filter is clever
Yeah
true desire
it's all true!!!
O - Stop it !!!! Your all very kind smile:D
All updates are sent through directly to your GI for you to select to update smile;)
In all seriousness thank all for comments, suggestions on this filter smile:)
Presidio
Presidio
Filters: 43
Hi Carl~
I couldn't let this one fall in the threads...
heading over to make filters now~
14 unregistered users.
