DJI
3D Jumbled Polygon Shapes #2 by DJI
http://www.filterforge.com/filters/15844.html ![]() "Art is quite useless." Oscar Wilde |
| Posted: May 20, 2021 1:46 pm | ||||||||
DJI
| Posted: May 20, 2021 1:47 pm | ||||||||
DJI
DJI
| Posted: May 20, 2021 1:48 pm | ||||||||
DJI
DJI
| Posted: May 20, 2021 1:49 pm | ||||||||
DJI
DJI
Nice and well done lovely 3D cubes and shards to use as a background
I would recommend to add 1 - an additional image overlay that could be painted all over the 3D shapes 2 - Be able to have multiple color shapes and not all the same colors 3 - Be able to also have some possible gradients colors options |
| Posted: May 22, 2021 6:05 pm | ||||||||
DJI
Thanx SpaceRay!
| Posted: June 1, 2021 1:54 pm | ||||||||
thanks, I think that it would not be difficult and I may try it myself
What I mean with this is it would be possible to make the polygon shapes with different colors selected by you with color controls and made them randomly distributed. You already have done a great filter for colorizing the polygon shapes based on a source image as can be seen in 3D Jumbled Polygon Shapes Photo Effect
But also you could apply this to this filter too, as it does not have the thin polygon shards that are on this other filter
What I mean with this is not as the image here above that the polygons are painted using the source image colors, what I suggest is similar to what you have already done and applied as diffuse map as you have done already in your 3D Jumbled Polygon Shapes #3 |
| Posted: June 3, 2021 12:09 pm | ||||||||
Another possible suggestion
From the above I got another idea Maybe you could try and test how it would look to mix this filter here with an overlay with your other well done colorful filter Multi-Colored Abstract Psyche-O-Delic Background Maker
also could test your other great and lovely 3D Colorful Abstract Wallpaper Generator
I mean that both of this could be done and applied as diffuse map as you have done already in your 3D Jumbled Polygon Shapes #3 |
| Posted: June 3, 2021 1:10 pm | ||||||||
