ken tompkins
[This may not be the topic for this item; if not, perhaps someone can move it where it belongs.]
As a new owner of FF I am trying to learn how to create filters. I've searched here and looked at the wiki but haven't found much on the PROCESS of creating them.
I understand that one of the best ways of learning is to examine filter examples to see how components react with each other. That is the stage that I am at. I have downloaded filters I am interested in and have been carefully examining how each component works.
I'm beginning to understand various common components; some are harder to understand than others. So, I use the help files constantly.
Ideally, I would have FF open on one monitor with the components splayed out across the screen an have an empty filter editor on another monitor for me to work on. I have an extra monitor but haven't figured out how to invoke two instantiations of FF.
At present, I have to open, close, open and close FF from an example to my attempt.
So, how have all of you learned this? I assume that you examined filters created by others? Did you take notes, do screen captures, create your own documentation? I am interested in the PROCESS and not, at this point, the content. Did you start with color or noise or an alpha image or....? Or doesn't it make any difference where in the chain of the components you start?
I have some, long experience with 3D modelers -- Carrara, Vue and Zbrush -- so I understand -- a bit -- such components as noise. I'm just sure where to start so I can maximize my learning.
I apologize for the length of this.
ken tompkins
learning is going to be different for every person. each brings his own knowledge already accumlated from elsewhere. for some, an art background has been employed. for others, a math background, maybe. so, everyone brings different things to the table.
thus, it boils down to, what do YOU want to do with the program? and that's where you start. what do you want as an end product and then work backwards from there. for me, that end product was mostly in the photo art area, so i wasnt so interested in textures as much as i was different effects on photographs. but, for others, it was ALL about the textures. thus, they may well have started somewhere different than i did.
so, you have two things there so far, what you already know and what YOU want to know.
the third is all about the program. what can it do? and what are the tools available within it? this again is going to be somewhat relative, since again, each person brings his own knowledge and purpose, but NOBODY is going to do very much effective if they dont know the tools. a carpenter trying to hammer a nail isnt going to get very far using a saw to do it. so, you have to know the tools. some folks already know a good deal, being photoshop users, or 3d program users or have other graphics skills and a certain familiarity with the various tool types in FF, but others will have to find out what a 'black point' is and what it does and whether to use a gaussian or normal blur. FF does help with this, though.
FF has a BIG advantage over other graphic programs. it's primarily visual. every component has a visual output where you can see what that component is doing to the overall effect you're creating. this is pretty huge and beats any kind of scripting or text type tool, hands down for learning. when one can instantly see a result of something applied, you learn right there and then. you can see the result instantly.
but, it still helps to know HOW things are done within each component. folks like Crapadilla, ThreeDee, Uber and some others, have a very good depth of understanding of how various components work, much better than myself. i tend to rely on the visual aspect of the components and a bit of a haphazard trial and error method. thus, those other folks can predict much better what a final result is going to look like, where i'm guessing quite a bit and fumbling around trial and error-wise with my way of doing things.
so, what you want, to save time, is prediction. how is somethign going to look BEFORE you ever plug it in? and that takes knowing how things work. the WIKI and help files are fairly technical. so, if you dont have much of a technical background, you're going to find yourself studing all sorts of things to get a handle on how things really work. i could give you an example of this, but it would probably put you to sleep smile:) but, suffice it to say, words are going to be key in figuring out how components work and how to predict a final output before you ever start plugging things in.
the help and wiki will give you some of the mechanics, like, why are some 'nodes' green, while others are gray and still others, blue. things like that, a lot of us picked up way back in the original beta test over two years ago. and, because we asked a lot of the same questions anyone else might that picks up this program, you can also find answers in the older pages of this forum. there's actually a LOT of good material hanging out back there on some of these pages.
so, you can work several different ways. you can just start plugging things into each other and see what happens, or, start with pure theory by reading and UNDERSTANDING all of the helps, wiki and forum pages, or, you can do a combo of both, which is probably the best way and the way i prefer in the long run... do, read, do some more, look up something i dont understand, do some more, ask questions on the forum, do some more, post up examples of my work, do some more, ask for some help on the forums, do some more and so on, ad infinitum.
so, does that cover any of what you wanted or am i just blowing smoke here? smile:)
If you actually used Vue in depth, you should actually have come across a very similar module (component) based system of texture creation.
The way I learnt this was basically through experiments and some logic. Filter forge can clearly look complicated to the first time user, but that should be same with many. If you ever open somebody else's filter you would have no idea what's going on. Sure, that happens a lot with me.
I began small steps. Made simple, easy filters which did simple things. Then I began adding components to see what happens. I eventually had some foundation to create much more complicated filters.
Having some kind of prior knowledge of what each component does helps a lot. So if you ever get stuck, read the manual. I swear, that sometimes helps me.
You can also go about imagining what you can make with Filter Forge. For example, the first filter I ever created made fictional country maps, complete with outlines, countries, and otherwise some textures.
Just begin thinking about what you want to do, then figure how you can achieve it.
That's how I got started with Filter Forge. smile;)
ken,
welcome to the forums and "Good Choice!" (smile:beer:) on your purchase! smile:D
In a nutshell:
smile;)
Ok, all kidding aside, I'd recommend the following procedure:
1) Start with the Filter Library: Open up various filters that interest you and play around with them. Change parameters here and there and observe how this changes the result. Hook up new components, change stuff around, ...
2) Once you got enough of the filter author madness, start a fresh Simple Filter and grab an Image component. Start adding components to the filter tree to modify the Image in various ways. Experiment heavily with map inputs. Don't aim at any usable result, just 'doodle' away and experiment freely without censoring yourself.
3) Rinse and repeat.
Some tips for analyzing filters:
- Examine how the author broke down the 'visual problem' that he faced into smaller and smaller 'visual problem units'.
- Try to identify the key 'building blocks' (i.e. functional groups of components).
- Examine how the various 'building blocks' are assembled to construct the 'solution' to the 'visual problem'.
- If you've got a very messy filter tree layout at hand, try reorganizing it into functional groups.
- Examine the order in which the operations take place inside the filter. Did the author have anything in mind using that particular order. What would happen if this order were changed?
An example:
Lounge Lizards
In order to 'solve' the 'visual problem' of 'leather couch', the author had to solve the following smaller 'visual problems':
* How does one make the basic leather bulge?
* How does one construct the seams? Ok, got seams now, but how does one rotate them to fit with the leather bulges?
* How does one create the buttons?
* How does one make the leather crease and crinkle?
* How does one give it all a slight irregularity?
* How does one generate color for that leather surface?
* How does one create different levels of reflectiveness for the leather and the buttons?
* What are the aspects of this texture that the user would want to have control over?
For each of these questions there is an answer inside the filter tree in the form of a component or a component group. If you can look at the filter tree and isolate these functional groups (or 'building blocks'), you're beginning to get into the mindset of a filter creator, and you're beginning to understand the PROCESS behind it... smile:)
You'll start noticing that there are certain 'recipes' that are used over and over again in many filters, techniques for solving certain basic visual problems if you will. Some examples of very basic visual problems inside FF would be:
* How do I create a circle?
* How do I create a layer of solid color?
* How do I create an outline for an arbitrary shape?
The best of these techiques are collected in the 'Snippet' category of the Filter Library, and they are used everywhere because they have been proven to be the most optimal solution. Familiarize yourself with these 'recipes' and it'll make your life much easier. No one wants to re-invent the wheel constantly... smile;)
Beliria
I learnt by listening to Crapadilla smile:D by looking inside others filters and playing around. Then I read a bit of the wiki stuff as well once I got a better feel for things. After that it's just a case of don't be scared to play around in there and see what you can come up with.
Other thing is when you are making a filter I find it best to save in stages, and keep making a new saved version just in case you change something totally and end up with a different filter look than you was originally heading towards.
ken tompkins
First of all, I want to thank those who responded to my query. Your suggestions are a wonderful review of your experiences with FF and I have captured them to my machine so I can read and re-read. It was kind of all of you to post.
Second, there are some excellent suggestions in your comments. For example, I am beginning to look at filters (as Crapadilla suggests) to identify the "building blocks" of various components. I hadn't noticed these groupings before. I'm also trying to see much of this as a visual experience and environment. What am I seeing -- in its parts -- and how might I create these visual elements in a filter?
Beliria suggests multiple saves and I'm adapting that to my work flow.
Most of you suggested "playing" and I'm enjoying pasting components together to see what I get. It's fun.
So, thanks again for your helpful responses. I stand in awe when I review what has been done here.
kt
Mike Blackney
Filters: 57
I'd like to see some of this information in an introduction to FF in the Wiki. I had a very similar time learning FF and it'd be a great way to stop newcomers from being too scared off by some of the hardcore effects smile:pimp:
I'd like to see some of this information in an introduction to FF in the Wiki. I had a very similar time learning FF and it'd be a great way to stop newcomers from being too scared off by some of the hardcore effects.
+1 for that.
So we have two volunteers already... Excellent! smile:devil:
125 unregistered users.
