I want to thanks a million for this incredible awesome, amazing and very useful component for me
Text Component help page here
I have seen the filter forge and you must add any of your custom fonts to the new Fonts folder available as shown below in the screenshot After adding the font file inside the folder, just restart FF and it will appear in the drop down list ready to use |
| Posted: January 3, 2025 2:28 pm | ||||||
I think this means that you can not submit a filter to Filter library with any CUSTOM text?? And what about single letters? |
| Posted: January 3, 2025 2:40 pm | ||||||
That is the way that I see it. Same as custom HDR environments if you submit a filter it will default to the default environment. Thus the filter will not look the way you designed it to. By text they mean font as well as text string. Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: January 3, 2025 2:53 pm | ||||||
Seems like that might get Globes 9x9 pulled from the library. I updated with the new fonts already. Using single letters.Talking about abuse... you could use Globes 9x9 to say bad things or curse words. So, we shall see.
Here's some Unicode painting for fun with Unicode fractions. ![]() Math meets art meets psychedelia. |
| Posted: January 3, 2025 10:15 pm | ||||||
double post
| Posted: January 3, 2025 10:23 pm | ||||||
Guess they would have to police that closer or implement something when submitting. Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: January 3, 2025 11:25 pm | ||||||
Thanks, I understand of course that you can NOT upload a filter with a custom font and will only use the built in ones from FF, the same as you can not upload any custom image. BUT that is different than a custom text that would be part of the filter, for example, if you make a filter with the text "Happy new year" or "Happy birthday" or any other text string, will it get removed and replaced by "filter forge" ?? maybe instead of guessing is needed to try it and test to submit a filter with custom text string and see what happens |
| Posted: January 4, 2025 3:45 am | ||||||
USE THE SCALE COMPONENT AFTER TEXT COMPONENT TO SEE IT BETTER
I have found that when you put a big amount of text, the text component preview is limited, but there is no problem, just simply add a Scale component and preview the result from scale ANIMATED TEXT Now is also possible animate text in multiple ways and also use bomber
well, I think that what is NOT allowed is to submit the filter with included bad words, BUT what the FF user does with the filter is his/her own responsibility and not FF You can have a car and you can destroy something or kill someone with it, and that does not mean that the car can not be available to buy, so I do not think it will be pulled from library because could write bad things. The same could be said about a simple ball pen, you can write many bad things with it and it is still being available.
Great and good creative idea, well done. I think that this opens a new huge world for MODIFYING artistically the letters and fonts with multiple filters and components to get other artistic alphabets and creative visual effects with textures and many more |
| Posted: January 4, 2025 4:02 am | ||||||
Thanks for all of your kind remarks, SpaceRay! Here is some research into Unicode and special characters. Music symbols are not included in most fonts, so here is a free font that has them called Noto Music. This font does NOT work properly with Word.
https://fonts.google.com/noto/specimen/Noto+Music International characters are supported in Arial Unicode MS. Microsoft now wants money for it... so try this. Copy and pasting is probably the best way (only way right now) to enter special characters into Text components. Here is my favorite Unicode character table. Just rolling over the character allows you to copy the character. Then you can see if the current font face in the Text component supports it. International characters are supported well in Arial Unicode MS. MS now wants money, so try this. If you find a symbol you want to use in an article or web page, you can find copy and paste the character into this Unicode decoder. Paste the Unicode into the left field and click Encode. The hex Unicode value (if the character is valid) will appear like \u03d0 , for example. ![]() Math meets art meets psychedelia. |
| Posted: January 4, 2025 2:24 pm | ||||||
WITH THE NEW TEXT COMPONENT YOU CAN CREATE ANY KIND OF INFINITE SHAPES, SYMBOLS AND OBJECTS THAT BEFORE WAS HARD TO MAKE
There are a lot of fonts that are based on Dingbats and also has some abstract or geometric shapes and now thanks to the new Text component you can import very easily all these shapes into FF in a very easy way without having to build them using FF components as it happened before in previous versions For example here above Rachel Duim has shown a great way to import music notes and other unicode symbols DAFONT DINGBATS EXAMPLES Scribbles shapes as fonts Splatter ink as font Different Artistic stars as font Arrows shapes as font There is a huge amount of dingbats and abstract fonts available that could be used Or you can design yourself a font with the shapes you may want and need
Thanks really very much for this very interesting and useful information and for showing this that is worthy and great |
| Posted: January 4, 2025 2:35 pm | ||||||
Cool SpaceRay! Great information.
Many fonts (Dingbats, Noto Music for instance) do not follow the Unicode standard. To find the special characters, use built in system tools that will allow you to copy and paste the special characters. On the Mac use Font Book. On Windows use Character Map. Math meets art meets psychedelia. |
| Posted: January 4, 2025 4:06 pm | ||||||
FF 14 Text compatible as I thought and expected is not compatible with OTF Opentype SVG color fonts but you can make them inside FF itself by using other filters available or make it yourself
HAVE NEON EDGES LETTERS AVAILABLE EASILY For example, I have found these color fonts that have a colorful gradient edges that may be sharp or soft edge (in FF you can customize it and is the beauty of FF) Culoare Neon Gradients edges OTF Color font Please continue in next post |
| Posted: January 6, 2025 12:05 pm | ||||||
| Posted: January 6, 2025 12:12 pm | ||||||
| Posted: January 6, 2025 12:15 pm | ||||||
Here is available the awesome filter StevieJ's NeonFluorescence and if you do not like the edge amount you can use the available "Effect Intensity" setting as edge width slider
Also if you maybe do not like the default result given as shown you can alternatively maybe add a slider to the gaussian component and see if it maybe gives a possible better result or not. It will depend on which font you are using. Continue Below |
| Posted: January 6, 2025 12:22 pm | ||||||
The only problem I see with this way described is that it makes rounded edges from a flat sharp edges font and is not like this example shown above (here repeated)
So the alternative for this is to try a different way and use layers, and have a filled Letter or text string with the gradients you may want using the threshold component and then with another Text component add a smaller sharp letter above the previous one You can then easily customize the edges of the below image to show it soft or sharp So it you will have something like this below continue for more below |
| Posted: January 6, 2025 12:43 pm | ||||||
BUT the problem with the possible alternative here above in previous post is that you WILL NOT be able to get the same artistic effect that is made with StevieJ's NeonFluorescence, so here I have found another different way and is to use this filter
Thick Outline Snippet By Malkyne You need to use this filter BEFORE feeding the letter or text string from the text component as you can see here below You will not have maybe perfect sharp edges (depending on settings) with some blur gradient but is better than what you have with the default StevieJ's NeonFluorescence |
| Posted: January 6, 2025 1:06 pm | ||||||
Maybe you want a different edge effect and there are more filters available, just use this link to search "outline thickness" in the filter library and you may find other options
Also there are available also other alternative Neon edges styles in this search of filter library Or search for Glow edges too in filter library as there are many too And you can also search for Edge detection on filter library with more options available I have not tested it myself, but as far as I know, I think that in all these above filters you only need to replace the source image with the text component |
| Posted: January 6, 2025 1:19 pm | ||||||
| Posted: January 6, 2025 1:59 pm | ||||||
| Posted: January 6, 2025 2:07 pm | ||||||
All the Neon and glow letters tutorial and suggestions starts In this post of this thread here
Please, if you may have any other possible idea, suggestion and alternative just put it here, thanks |
| Posted: January 6, 2025 2:09 pm | ||||||
I have faux bold and faux italic in the font group at the right before the group outputs in Globes. Minor but useful. Bolding can be converted for outlining as as well.
| Posted: January 6, 2025 5:29 pm | ||||||
| Posted: January 9, 2025 2:16 pm | ||||||
Filter Forge 14 supports TrueType fonts (.ttf). In both Windows and on the Mac there are many other font types: .otf (Open Type), TrueType collections (.ttc), and other various font types (.dfont, .fon, and more). You can convert these fonts to .ttf by using online tools.
On the Mac and Windows you can use FontForge ( https://fontforge.org/en-US/ ) to create multiple .ttf files from .dfont or .ttc collections. When you load a collection, you are prompted for which part of the collection you want to load. Then to create the single .ttf, go to File/Generate Fonts…/ , then set the output type to TrueType, then Generate. Close this version of the font, then reload the .ttc for each .ttf you want. Note that the interface requires hitting Return or OK when navigating through folders (no double clicking), a UNIX like UI. For converting most other fonts, I prefer this tool for converting to .ttf: https://www.fontconverter.org/ Easy to use, upload the font, start conversion, then download the .ttf. Be aware that some fonts can’t be converted, the file is protected by a EULA flag. Location of fonts: Mac: /Library/Fonts /System/Library/Fonts /Users/<username>/Library/Fonts Windows: \Windows\Fonts \Users\<username>\AppData\Local\Microsoft\Windows\Fonts Math meets art meets psychedelia. |
| Posted: January 15, 2025 11:49 pm | ||||||
Posts: 3507 |
Thank you Rachel.
I'd like to add than you can't be 100% sure that each and every TTF file will be compatible with FF. TTF is a very broad format that can contain almost anything, for example embedded bitmaps. Such TTF files are uncommon but they do exist, and they will crash FF upon loading. Unfortunately there is no easy way to tell a compatible font file from an incompatible one. If you encounter a crash after loading an exotic font just remove the file and try a different one. |
| Posted: January 17, 2025 8:47 am | ||||||
I have thought that I have found a way to be able to use color fonts too additional to the new text component and is based on what Threedee made already with the Arial letters, but instead of using FF letters it would be replaced with a color control so you can load a PNG or JPG of the color font you want to use
This is the Arial font made awesomely by Threedee but replacing the letters with a color control, will make it, test it and see if it works as expected |
| Posted: August 3, 2025 5:35 pm | ||||||
I totally agree that is impossible that FF can guarantee that any TTF font will work because as you said very well there is really a huge amount of different TTF fonts available and many do not follow a standard or may have too much glyphs or some features that are not compatible with FF and may also give problems with other graphics software and not just only with FF |
| Posted: August 20, 2025 2:31 am | ||||||
Also now there is a possible way to add special effects to text and fonts and be able to change the font to any black and white to use as a shape or base and apply the effects to any font
There is a very good, awesome and amazing example that Rachel Duim have made to show this Flashing Messages 3x6 (Texture) |
| Posted: May 28, 2026 11:48 am | ||||||
Please, does anyone know how to be able to increase or decrease the size of any font you may use with a slider setting?
I have tried to use Min and Max components or adding progressive scaled version and then blend them but the font gets distorted and does not follow the same shape of the original font, and furtermore the inscreasing is not linear and central if do it with scale, so maybe I should need to keep it fixed. I will ask to AI if I may be missing something that I do not know |
| Posted: July 6, 2026 1:36 pm | ||||||
Nope, all the sliders are self contained in the component. Anything that you do will not control the text the same way as the text controls do on that component. As you know there are plenty of workarounds to working with text but keeping the original at a fixed size is a lot easier to control...It also depends on what you want to accomplish with the text...
| Posted: July 8, 2026 11:08 am | ||||||
17 unregistered users.
