ddaydreams
Frank Hawkins
Is there an FF Filter that can taper/reduce the line size gradually from inside to outside, making all lines thickness the same at the middle but gradually thinner at the outer edges, like a starfish. I was thinking something like a radial threshold might be involved. Is there some filter or snippet that can convert this image into the starfish type shape I'm referring to?
Sphinxmorpher
Outer and inner corners along with star parameter of the Polygon component is not what you're looking for?
Sphinxmorpher
ddaydreams
Frank Hawkins
YES! That Blowfish filter does the trick. Thanks Much smile:)
