twocents
twocents
To transfer library filters from FF7 to FF8 you need to copy two files and one folder:
Library\
Library.xml
LibraryStructure.xml
FOR MAC:
from
/Users/Your_User_Name/Library/Application Support/Filter Forge 7/System
to
/Users/Your_User_Name/Library/Application Support/Filter Forge 8/System
FOR WINDOWS:
from
%APPDATA%\Filter Forge 7\System\
to
%APPDATA%\Filter Forge 8\System\
To transfer user-made filters, environments and custom presets you need to copy the corresponding folders:
from
to
or from
to
I just upgraded to version 3. Can I import filters from the older version?
Thanks.
[Original message edited by moderator to be able to post on top]
Gill Brooks
GillB
I just copied all my filters over from the appdata folder smile:)
C:\Users\YOURPC\AppData\Roaming\Filter Forge 2\System\Cache
C:\Users\YOURPC\AppData\Roaming\Filter Forge 2\My Filters
Gill
Please see this thread here for full information
James
James
Filters: 46
This method has worked fine for me in the past but from what i remember last time i tried this i was offline then first needed to connect to the internet before the filters listed correctly.
That is not a problem for me at the moment with this computer as i have been using the built in updater tool and have not needed to transfer any filters just yet. I was thinking about using my 8GB USB storage to transfer the filters and install FF3 on a laptop without a web connection however which might cause some problems.
Is there a way to do it without a web connection also or would that not work?
James, you need to transfer
%APPDATA%\Filter Forge 3\System\ and
%APPDATA%\Filter Forge 3\My Filters
to another computer. This doesn't require an internet connection.
James
James
Filters: 46
Thanks GMM, i have now installed FF on my laptop and transferred the filters, it was a very simple process and everything seems to work great. smile:)
I think this will be useful for the ones that want to transfer filters from FF 3.0 to the new FF 40
I modified the first message here to be able to post the full instruction.
WordWeaver
Thank you for these easy-to-follow instructions.
On my Mavericks-run iMac, I copied the three items Library, Library.xml and
LibraryStructure.xml from here:
/Users/Your_User_Name/Library/Application Support/Filter Forge 3/System/
to here:
/Users/Your_User_Name/Library/Application Support/Filter Forge 4/System/
After that, I synched with your server when prompted to do so, checked for filter updates, and checked for app/plugin updates.
So far, everything seems to be working fine.
Now that I have imported everything from FF 3.0 to 4.0, I imagine that if I want to completely delete FF 3.0 from my hard drive, I would remove the following:
"Filter Forge 3" folder from the "Applications" folder
"Filter Forge 3" folder from the "~/Library/Application Support" folder
"FilterForge.pluginv3" alias from the Adobe Photoshop CS6/Plug-ins/Filters" folder
Am I missing anything? I didn't find any prefs files in "~/Library/Preferences".
Oh, if I may make a suggestion: It would be great if with each major release, you included some code which would give a user the option to automatically import filters from a previous version of the app to a new version of the app.
Thanks for listening, and thank you again for a fine product. smile:)
WordWeaver
I'm not an expert in Macs but I think you're right. There are no pref files in "~/Library/Preferences".
WordWeaver
GMM, upon using a program uninstaller called CleanApp, I discovered that there is another folder that needs to be removed as well called "com.FilterForge.FilterForge3.savedState".
This particular folder is found here:
~/Library/Saved Application State/
Thus, as far as I can tell, to completely uninstall a previous version of Filter Forge from a hard drive on a Macintosh OS X machine -- after moving your filters to the new version -- the following four items need to be removed:
"Filter Forge 3" folder from the "Applications" folder.
"Filter Forge 3" folder from the "~/Library/Application Support" folder.
"FilterForge.pluginv3" alias from the Adobe Photoshop CS6/Plug-ins/Filters" folder.
"com.FilterForge.FilterForge3.savedState" folder from the "~/Library/Saved Application State" folder.
WordWeaver
Rod_D
have you seen my eraser?
Filters: 3
In m y version of Windows 8.2 64 bit they are found here.
C:\Users\Rod\AppData\Roaming\Filter Forge 4\System
And should be moved here
C:\Users\Rod\AppData\Roaming\Filter Forge 5\System
Rod
Arioch
Arioch
This seems to have worked perfectly for me going from FF8 to FF9 as well.
SlowX
How about going from FF10 to FF11?
jess
jess
i just installed ff 14 on my computer. i have versins 9,11,and 13 installed.
question#1 - do i need to keep the older versions on my pc?
quewstion #2 - ifi have downloaded filters on the older versions, how do i save them to the new version?
thanks for any help!
jess
jstech
33,788 Registered Users
+11 new in 7 days!
15,373 Topics
31 unregistered users.
