Kork
We were just trying around with the new 2.0 and fiddled with the offset filter. Much to our surprise we noticed that the offset filter does no longer wrap the image around (e.g parts of the image that are offset outside the image area will be inserted on the other end). This worked in 1.x. Is this intended? If so, how can we get an offset that wraps in 2.x?
Kind regards,
Jan
I would say first to make sure that seamless tiling is on.
Kork
Hmm this one is disabled and it's probably disabled by the "free rectangle" component. Wonder why this prevents seamless, where "frame" does not.
Ah. Free Rectangle disables seamless because you can have the rectangle outside image boundaries, hence the "Free" in the name. If you had half a rectangle on the right side of your image, do you think it would be very seamless? smile;) smile:)
Kork
Well if it wraps around it would be. So basically i am stuck with frame and offset then?
Here's what I suggest, do a Polygon snippet that's not free, then just use the offset component, that should work.
Kork
That does the trick, thank you smile:)
Though being able to set position AND size within ONE component would be more convenient (which is why we opted for "free rectangle" i the first place). So now if I need like 16 different rectangles I need 32 components (16 polygon and 16 offsets). Maybe in a later version, free rectangle can be made seamless (in fact you can do anything in free rectangle with a combination of polygon and offset, so I really don't see why this wouldn't work).
Well, the polygon doesn't allow you to place the radius outside image boundaries, allowing it to wrap seamlessly. smile:)
Kork, we have pairs of components exactly for this purpose. If you need seamless tiling use Polygon, Ellipse and Profile Gradient instead of their 'Free' counterparts. Note that Offset doesn't break seamless tiling.
33,762 Registered Users
+19 new in 30 days!
+6 new in 7 days!
15,363 Topics
21 unregistered users.
