Your unpowered SSD is a ticking time bomb
Your data and your files and work you do with your computer is very important, valuable and worthy and it would be a great big loss if it gets corrupted and you loose it
So I wish you never loose any data so I want to help and give a warning here for you to be safe and avoid any possible problems
I have just found this very interesting and useful article that goes against what many people may think and believe that SSD hard drives are safer and better than mechanical hard drive for cold storage and backup
I have always believed that storing and keeping data in a SSD hard drive, or using external SSD drives would be much better and much safer than using an external mechanical hard drive, but according to this research above this seems to be totally wrong
So please, I would advise and recommend that you may read this and be aware of not keeping your SSD without use for much time as they would become maybe useless and would be a real big pity that you find you have lost your most precious and valuable data and files and all your hard work
And as it being said is not also recommended to make just one only backup because it could also fail and then you lost it
Wish you all the best and that you can continue many years without problems with your hard drives either SSD or mechanical
33,776 Registered Users
15,368 Topics
+55 new in year!
22 unregistered users.
