Raschid Abdul-Nour
Raschid Abdul-Nour
Filters: 4
Hi!
It's been a while since I used FF for the last time (in PS), but as far as I remember, in PS the plugin did use the size of the document itself as the output size of the image FF generated, or, alternatively the size of your selection, right?
While FF 14 seems to generally run in Affinity V3, it doesn't seem to run well with Artboards in Affinity. I have several artboards in my document, and the size FF generates is always the bounding box of all artboards (so it's usually huge in my case). You can see this size in the documents details, for example in the top bar of the Pixel Studio.
I understand that Artboards don't exist in PS, and I could live with making a rectangular selection of the artboard in which I want to insert the FF content, but it still uses the size of all artboards together.
Any way around this, that I'm not getting?
Cheers!
westdale
Filters: 7
Similar issue here, possibly the same.
The behaviour seems to be for me that when passing a selection (small pixel item in an A4 document) to FF14, it receives the area of the whole A4 document.
If we call that the bounding area of the known world in my case, and that includes all artboards in your case - it seems to be the same.
Whether that is an Affinity issue or a Filter Forge issue or an ' things have just changed, Affinity 3 is a very different animal, that's how it is now' remains to be seen.
Raschid Abdul-Nour
Raschid Abdul-Nour
Filters: 4
Hi!
I just wanted to point out, that the issue seems to be fixed in Filter Forge 15. It uses (only) the currently selected Artboard now when working with Affinity 3
33,759 Registered Users
+17 new in 30 days!
15,361 Topics
+65 new in year!
