The Draft Mode button scales down the content in FF14.004 on Mac Sequoia 15.7.2. I've attached the filter that shows the issue. A side effect of this: Preview Animation also shows a scaled down version.
Spining Letters 01.ffxml Math meets art meets psychedelia. |
| Posted: November 13, 2025 6:36 pm | ||||
I posted about this here Output goes pink
| Posted: November 13, 2025 8:26 pm | ||||
This also does the same thing on Windows but with only certain filters. I have uploaded a video of that here. Pink output
| Posted: November 13, 2025 8:29 pm | ||||
Posts: 3498 |
That post is from May 2025. Please try the latest build (from October 2025): https://www.filterforge.com/download/ and check if the issue still persists. |
| Posted: November 14, 2025 8:34 am | ||||
The 14.004 build is later (from April to October on Mac), but it does not fix the issue. You can use this, just push the Draft button. Also the program didn't ask for an update, I had to do it manually.
Update: Size, pixels is not right for this filter, in regular mode. Spining Letters 01.ffxml Math meets art meets psychedelia. |
| Posted: November 17, 2025 7:28 pm | ||||
Posts: 3498 |
Rachel, here is a video recorded by our QA engineer: https://www.dropbox.com/scl/fi/8cle3zp...1k8vh&dl=0 We see no pink output. You're welcome to help with reproducing the issue. What steps do we need to take? |
| Posted: November 28, 2025 7:31 am | ||||
I thought the error I had was related to the pink background issue. I was wrong.
To illustrate the issue i'm having, here is the spinning letter filter I attached above rendered in final mode (default preset, 400x400 blank image): https://duim.com/animate/spiningletters-test04.webm If I render it in 50% Preview, the results are different: https://duim.com/animate/spiningletters-test03.webm Also seems that draft mode also causes this issue. FWIW Math meets art meets psychedelia. |
| Posted: December 1, 2025 9:19 pm | ||||
UPDATE: the same issue exists in FF15, Preview video changes letter position and size. So does Draft mode.
| Posted: December 18, 2025 11:17 pm | ||||
Odette
Posts: 1 |
Bonjour,
Pourriez-vous m'expliquer comment faire passer la flamme animée (mais sans arrière-plan) qui se trouve dans filter forge animator dans filter forge 14 pour pouvoir poser l'animation sur une image. Merci, Robette. |
| Posted: December 20, 2025 11:53 am | ||||
33,762 Registered Users
15,363 Topics
34 unregistered users.
