PixelStar
PixelStar
Filters: 2
Good Afternoon, Folks
I am using FF 14 Studio and am trying to teach myself animations. I have successfully done a few, however, I am stuck on not knowing how to get the animation to successfully loop... that is, at the end of the animation, it skips. I have tried using curves and tone curves and I cannot seem to get the animation to loop smoothly. I spent an entire day and went through what I could find here.
Can someone walk me through this?
Filters: 190
Yes, I will provide some examples later of repeating functions (like sine waves) vs non-repeating functions (like offset).
PixelStar
PixelStar
Filters: 2
Thanks!
I did try hooking a tone curve into the end of one of my filters and placing a wave curve with Normalized time connected to the "phase" in the wave; I then changed the minimum and maximum to opposite in the "remapping" of the normalized time.. this still didn't work; I also tried changing the number of frames from 90 to 100 then to 200
Filters: 268
It also depends on what you are trying to loop. What does the final image look like compared to the beginning image..
Filters: 190
Here is an example of a repeating function (sine) and the other animation, an offset in FF14. The first one is continuous. The second is not, so I break the animation up by going from time 0 to 1 to 0 to .5, then .5 to 0, doing the appropriate math to offset from -.25 to .25. I can provide more info if needed.
animate examples 01.ffxml
PixelStar
PixelStar
Filters: 2
I am unable to download your example.. it only opens to code on a new tab page.. tried with other browsers and same.. is there a way to open this besides code?
PixelStar
PixelStar
Filters: 2
BTW thank you.. I feel silly that I am such a newb smile:D
PixelStar
PixelStar
Filters: 2
I saved the web page and FF opened it automatically..smile:?: smile:blush: smile:blush: smile:D
Filters: 190
Filter Forge filters have the file extension .ffxml. Don’t know if you are using Windows or a Mac and what version. The file extension .ffxml needs to be associated with the filter Forge 14 application. If you don’t know how to do this, let me know your operating system and version And which browser you use.
Update:if you did get it to work the filter will be in the My Filters folder
33,770 Registered Users
+12 new in 30 days!
15,366 Topics
+58 new in year!
12 unregistered users.
