This is really cool and I did miss this before, and must congratulate for the patience and hard work for being able to build this perfect TV signal with so much detail and quality
Is awesome and amazing how you made it
And being this a filter forge filter, you could also replace the plain colours, with different bit of images that my be input individually instead of just plain colours as this is the beauty and power of FF
Filters: 700
Thank you! smile:D
I will check about your idea to allow images to be used instead of colors. At first glance it seems difficult. Because it should also allow to offset and resize every single image, otherwise it would not be possible to center the images in the right spaces. It would require a lot of controls, making the filter rather complex to use. Anyway I will try. Let's see.
I am very sorry that I did not clarify and put it right as you showed it could be understood wrong, because I did not want to replace every single color with images.
I am just ONLY refering to just only the 6 COLOR CENTRAL SQUARE images in the center, because this are easy to replace with source images
sorry for the possible confusion
sorry, is not needed to add any offset controls as it would be just the central squares and not the other ones.
Filters: 700
I think I will make a new Monoscope filter. I plan to add writings too. smile;)
33,776 Registered Users
15,368 Topics
+55 new in year!
