Fr om the awesome and amazing Flipping Image Animation by Rachel Duim as shown here
I have thought to make it even further and use bomber plus where the 20 images are arranged into 10 different groups wh ere the starting point of each group is different, so the bomber plus would get feed with 10 different animations. I mean that there could be possible to create a grid with random squares animated that the starting image is chosen randomly and so each animation on the grid would be different
The way I have thought it would be possible I think is what you say here, Have 10 different switch components with each one have different arrangements of the images and then use the bomber plus randomizer and the selector of all the switches I do NOT want that each one in the grid is different, just only that there are 10 different animated squares feed randomly arranged in the grid on the bomber plus I have made a fast test and it seems to work, here is an example below with just two Switchs to see if it would be possible So I will continue adding the remaining 9 switch components groups |
| Posted: April 1, 2025 10:17 pm | ||||
Here is my "solution":
No randomness at all. Using the ordered list starting at a different place. I slowed it down so you can see what's going on. Using Loop, not Bomber+. Math meets art meets psychedelia. |
| Posted: April 2, 2025 12:55 am | ||||
WOW, this is really well done and none of the nearby images are repeated, very clever to use loop I made a new version using the mega switch by totte (available in Arial letters by ThreeDee) so you can put all 20 images in just one only switch and connect it directly to the input of bomber plus with a randomizer slave The result shown below ia not what I wanted but is curious and still cool, but like much more yours. |
| Posted: April 2, 2025 4:45 pm | ||||
I've attached the beta version. Probably release it as a Snippet eventually. It works up to a 7x7 grid. In FF14.
![]() Flipping Image Grid beta.ffxml Math meets art meets psychedelia. |
| Posted: April 2, 2025 11:35 pm | ||||
Sorry I forgot to give a huge thanks very much for having taken the time to create this and is a complex one, and I admire much how you can be able to do this and congratulations
| Posted: April 16, 2025 5:25 am | ||||
| Posted: April 22, 2025 8:27 pm | ||||
33,742 Registered Users
15,356 Topics
14 unregistered users.
