PixelStar
This is happening very frequently. Using FF Version 13 Pro, I submitted a bug report but not sure I was as clear as I could be reporting it so I am reporting it again here.
Computer specs: Windows 11 Home; Laptop with Core i9 13900HX; 64 gb memory; Geforce RTX 4070 Laptop When: while in filter editor or Group/snippets How: if I spread my filter modules apart -trying to organize them, it crashes; it crashes as I move around/scrolling fr om one part of the filter to another. Can your team make it to where there is a much larger area within the filter editor that I can spread out the modules? Do you think it has something to do with the "dont panic" feature? Couldn't you make a "center it" button/feature while in the filter editor? So this doesn't just happen as a result of getting lost in the filter editor.. finding the filter modules. I am focused right on the modules and then attempt to scroll down to fix another part of my filter and that is when it crashes. Example: My filter has an image and manipulation to the image; then other parts blended into it such as a frame, etc.. when I scroll over to the frame part or whatever, this is when it crashes.
This is also happening when I am editing a "group" or snippet in the filter editor - it gets lost out of bounds, then while trying to scroll around, trying to find my end point of the filter, it crashes. Do you think maybe there is a limit as to how "hefty" or complex the filter can be? I have found the group and create snippet feature really useful, but not if adding it is going to crash the filter over and over. And after this is all said and done, after it crashes, it somehow disappears from wh ere I have bookmarked it within my favorites folders. So I have to add it back all over again |
| Posted: November 7, 2024 10:26 am | ||||
PixelStar
Here are more screenshots of "Version 13 - Frequent crashes Creating Filters" After I reproduced the crash, it is gone from my saved place within my favorites folders
I have tried to make the filter smaller and more compact within the filter editor and this doesn't help. I have updated all of the components of the filter to match Version 13 and this doesn't seem to make any difference either |
| Posted: November 7, 2024 10:28 am | ||||
PixelStar
I reproduced the error again with this filter.. this time trying to unplug my "group snippet" from the filter. I don't know if you find this information useful, but the submit bug doesn't have a way to do screenshots. Also, I noticed this time, it happened when I was scrolling/zooming OUT within the filter editor space so I could see the filter better. If I stay zoomed in, it doesn't happen as much
Here it is: Operating system: Windows 10 x64 Edition (10.0 build 22631) Physical memory: 65275 MB Number of processors: 32, available: 32 Processor info: 13th Gen Intel® Core i9-13900HX, ~0 MHz Filter Forge x64 13.005.4275.16034 Release, February 15, 2024 12:53 [11/7/2024 9:38:57 AM -0600] [Controls::Control] Exception occured while processing window message 0x0000000F(WM_PAINT) (0x00000000 0x00000000) for window 00000000000A0B30/00000000000A0B30, control: <class Controls::FilterEditor>@00000000174A1840. Critical exception occured at thread 0000000000003C40 'Application': <class XFW::Exception> Application encountered an unrecoverable critical error and will be terminated. Critical exception call location: <unknown file>(0) : <unknown function>()+0 at 0000000140DCBE60 in C:\Program Files\Filter Forge 13\Bin\Filter Forge x64.exe(0000000140000000) <unknown file>(0) : <unknown function>()+0 at 0000000140DBE64B in C:\Program Files\Filter Forge 13\Bin\Filter Forge x64.exe(0000000140000000) <unknown file>(0) : UnhandledExceptionFilter()+492 at 00007FFDD117B21C in C:\Windows\System32\KERNELBASE.dll(00007FFDD1010000) <unknown file>(0) : LdrResolveDelayLoadsFromDll()+5234 at 00007FFDD3ACABD2 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : KiUserApcDispatcher()+176 at 00007FFDD3A94080 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : _chkstk()+303 at 00007FFDD3A9517F in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : RtlFindCharInUnicodeString()+2710 at 00007FFDD3A0E856 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : RtlRaiseException()+405 at 00007FFDD3A44925 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : RaiseException()+108 at 00007FFDD106FE4C in C:\Windows\System32\KERNELBASE.dll(00007FFDD1010000) <unknown file>(0) : <unknown function>()+0 at 0000000140DC339D in C:\Program Files\Filter Forge 13\Bin\Filter Forge x64.exe(0000000140000000) <unknown file>(0) : RtlCaptureContext2()+1190 at 00007FFDD3A949C6 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : <unknown function>()+0 at 000000014044DA45 in C:\Program Files\Filter Forge 13\Bin\Filter Forge x64.exe(0000000140000000) <unknown file>(0) : DispatchMessageW()+1857 at 00007FFDD20C83F1 in C:\Windows\System32\USER32.DLL(00007FFDD20B0000) <unknown file>(0) : DispatchMessageW()+1020 at 00007FFDD20C80AC in C:\Windows\System32\USER32.DLL(00007FFDD20B0000) <unknown file>(0) : GetClassLongW()+1421 at 00007FFDD20D31DD in C:\Windows\System32\USER32.DLL(00007FFDD20B0000) <unknown file>(0) : KiUserCallbackDispatcher()+36 at 00007FFDD3A94114 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) [Controls::Control] Exception occured while processing window message 0x0000000F(WM_PAINT) (0x00000000 0x00000000) for window 00000000000A0B30/00000000000A0B30, control: <class Controls::FilterEditor>@00000000174A1840. Critical exception occured at thread 0000000000003C40 'Application': <class XFW::Exception> Application encountered an unrecoverable critical error and will be terminated. Critical exception call location: <unknown file>(0) : <unknown function>()+0 at 0000000140DCBE60 in C:\Program Files\Filter Forge 13\Bin\Filter Forge x64.exe(0000000140000000) <unknown file>(0) : <unknown function>()+0 at 0000000140DBE64B in C:\Program Files\Filter Forge 13\Bin\Filter Forge x64.exe(0000000140000000) <unknown file>(0) : UnhandledExceptionFilter()+492 at 00007FFDD117B21C in C:\Windows\System32\KERNELBASE.dll(00007FFDD1010000) <unknown file>(0) : LdrResolveDelayLoadsFromDll()+5234 at 00007FFDD3ACABD2 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : KiUserApcDispatcher()+176 at 00007FFDD3A94080 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : _chkstk()+303 at 00007FFDD3A9517F in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : RtlFindCharInUnicodeString()+2710 at 00007FFDD3A0E856 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : RtlRaiseException()+405 at 00007FFDD3A44925 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : RaiseException()+108 at 00007FFDD106FE4C in C:\Windows\System32\KERNELBASE.dll(00007FFDD1010000) <unknown file>(0) : <unknown function>()+0 at 0000000140DC339D in C:\Program Files\Filter Forge 13\Bin\Filter Forge x64.exe(0000000140000000) <unknown file>(0) : RtlCaptureContext2()+1190 at 00007FFDD3A949C6 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : <unknown function>()+0 at 000000014044DA45 in C:\Program Files\Filter Forge 13\Bin\Filter Forge x64.exe(0000000140000000) <unknown file>(0) : DispatchMessageW()+1857 at 00007FFDD20C83F1 in C:\Windows\System32\USER32.DLL(00007FFDD20B0000) <unknown file>(0) : DispatchMessageW()+1020 at 00007FFDD20C80AC in C:\Windows\System32\USER32.DLL(00007FFDD20B0000) <unknown file>(0) : GetClassLongW()+1421 at 00007FFDD20D31DD in C:\Windows\System32\USER32.DLL(00007FFDD20B0000) <unknown file>(0) : KiUserCallbackDispatcher()+36 at 00007FFDD3A94114 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) |
| Posted: November 7, 2024 10:42 am | ||||
Posts: 3498 |
Thanks for your report but without the filter file we're unable to look into your issue. Please attached it here or submit to the library. |
| Posted: November 7, 2024 10:51 am | ||||
PixelStar
Ok, I will attach it here, but it really is not a "submittable" filter I think....to the library
For 2 reasons and one is a question: 1) it is not in a place to be workable yet 2) it is a filter that is modified by other users and I was updating combining, experimenting and adding functions from these "other" filters via the group function to enhance it. The reason I did not upload it is that both of these received a reward and I was merely updating these for my own purposes.. This brings up the Question: Am I even allowed to add filters such as these to the library? The filters' author is: Cartography: This filter created by Crapadilla - I updated / modified elements within the filter Old Parchment: This filter created by Crapadilla - I updated / modified elements within the filter Cartography Revamped.ffxml |
| Posted: November 7, 2024 11:14 am | ||||
PixelStar
I just noticed there is a "zoom to fit" button.. my bad for not seeing this, I will have to try that next time. Either way when I scroll out using the mouse in the editor, that seems to be when it crashes
| Posted: November 7, 2024 11:33 am | ||||
Posts: 3498 |
What window scaling setting do you have?
Please navigate to 'Display settings' > 'Change the size of text, apps and other items' and set scaling to either 100, 150, or 200. |
| Posted: November 8, 2024 6:58 am | ||||
PixelStar
This time I tried it at 150 display through windows 11 settings and also at 100. Both gave me a termination. it happened when I tried to create a new filter. I had not saved the filter yet. I wanted to test the filter before saving and I went to change the window size within the filters settings at the very bottom "size, pixles" .. it had been pushed to zero on the slider and isn't it usually defaulting to 600 or 700 pixels?
I got this with display set at 100: Operating system: Windows 10 x64 Edition (10.0 build 22631) Physical memory: 65275 MB Number of processors: 32, available: 32 Processor info: 13th Gen Intel® Core i9-13900HX, ~0 MHz Filter Forge x64 13.005.4275.16034 Release, February 15, 2024 12:53 [11/11/2024 3:54:58 PM -0600] [Controls::Control] Exception occured while processing window message 0x00000201(WM_LBUTTONDOWN) (0x00000001 0x0008000D) for window 00000000001E0C28/00000000001E0C28, control: <class Controls::TrackBar>@0000000013C2A320. [Controls::Control] Exception occured while processing window message 0x00000008(WM_KILLFOCUS) (0x001E0C0C 0x00000000) for window 00000000001E0C28/00000000001E0C28, control: <class Controls::TrackBar>@0000000013C2A320. Critical exception occured at thread 0000000000002034 'Application': <class XFW::Exception> Application encountered an unrecoverable critical error and will be terminated. Critical exception call location: <unknown file>(0) : <unknown function>()+0 at 0000000140DCBE60 in C:\Program Files\Filter Forge 13\Bin\Filter Forge x64.exe(0000000140000000) <unknown file>(0) : <unknown function>()+0 at 0000000140DBE64B in C:\Program Files\Filter Forge 13\Bin\Filter Forge x64.exe(0000000140000000) <unknown file>(0) : UnhandledExceptionFilter()+492 at 00007FFDD117B21C in C:\Windows\System32\KERNELBASE.dll(00007FFDD1010000) <unknown file>(0) : LdrResolveDelayLoadsFromDll()+5234 at 00007FFDD3ACABD2 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : KiUserApcDispatcher()+176 at 00007FFDD3A94080 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : _chkstk()+303 at 00007FFDD3A9517F in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : RtlFindCharInUnicodeString()+2710 at 00007FFDD3A0E856 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : RtlRaiseException()+405 at 00007FFDD3A44925 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : RaiseException()+108 at 00007FFDD106FE4C in C:\Windows\System32\KERNELBASE.dll(00007FFDD1010000) <unknown file>(0) : <unknown function>()+0 at 0000000140DC339D in C:\Program Files\Filter Forge 13\Bin\Filter Forge x64.exe(0000000140000000) <unknown file>(0) : RtlCaptureContext2()+1190 at 00007FFDD3A949C6 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) <unknown file>(0) : <unknown function>()+0 at 000000014044DA45 in C:\Program Files\Filter Forge 13\Bin\Filter Forge x64.exe(0000000140000000) <unknown file>(0) : DispatchMessageW()+1857 at 00007FFDD20C83F1 in C:\Windows\System32\USER32.DLL(00007FFDD20B0000) <unknown file>(0) : DispatchMessageW()+1020 at 00007FFDD20C80AC in C:\Windows\System32\USER32.DLL(00007FFDD20B0000) <unknown file>(0) : GetClassLongW()+1421 at 00007FFDD20D31DD in C:\Windows\System32\USER32.DLL(00007FFDD20B0000) <unknown file>(0) : KiUserCallbackDispatcher()+36 at 00007FFDD3A94114 in C:\Windows\SYSTEM32\ntdll.dll(00007FFDD39F0000) |
| Posted: November 11, 2024 5:01 pm | ||||
33,770 Registered Users
+12 new in 30 days!
15,366 Topics
+58 new in year!
11 unregistered users.
