Filters: 698
Since the last Filter Forge update I have sometimes had <class XFW::Exception> error.
I am using Filter Forge 13.005 Studio Edition
It had never happened with 13.004 Studio Edition.
The error happens using the editor, while connecting components.
Thanks for your report but we cannot reproduce this issue. Components connect fine for us. If you happen to notice a more specific pattern that always leads to the error message and can be reproduced, please send us the failing ffxml file.
Filters: 698
Thank you. Next time I will try to see if I can get more information. smile:)
Unfortunately, until now, when this error happened, I could not get any ffxml file, because Filter Forge wasn't responsive.
Filters: 698
Unfortunately I continue to have this error.
It happens using the editor. Not only connecting components but also in other situations. This time I was working on a Map Script.
It shuts down Filter Forge, so it is not possible to send any report by email as I usually do when I get errors.
I can only suggest to check what was changed in the editor from the previous version of Filter Forge to this, because it never happened before.
33,762 Registered Users
+27 new in 30 days!
15,363 Topics
33 unregistered users.
