Beat
Beat
Thank you Vladimir to include the Dividers in the UI in FF13. Especially good as they also have the possibility to give them a label.
This is a BIG improvement for the UI.
Other suggestions, that might make the UI better smile:-)
• Longer names possible.
• Color Coding of controls.
• PopUp menus . I just can't forget them smile:-)
• In the editing mode : When the chain components has been disconnected somewhere (especially at the end), even when a connection is swapped out, the order of the controls can be severely scrambled. I counted recently, and I had to click 468 times to get my controls back into the order they were before a swap of connections. This is at the least cumbersome and could be done better, I suppose.
Best, TheBeat
Beat
Beat
It would also be great if it would be possible to place a Slider and a Checkbox on the same line in the UI.
That would make things more organized in appropriate cases and it takes less vertical space.
33,778 Registered Users
15,368 Topics
+54 new in year!
17 unregistered users.
