Valhalla
Valhalla
This script inserts a random seed in the seed box when you right click the render button. Things to know: Make sure your seed is visible until I enhance the script since it's a very rough draft. Only tested on a 4k screen, but I used location of the seed box edit8 so hopefully it will work on any screen size.
To use google AutoHotkey and download version 1 and install it. Once installed make a new text file, paste the following code into it, save and close the text file. Then change the text file extension from .txt to .ahk and you'll be able to run it.
Code
#SingleInstance, Force
#Persistent
SetKeyDelay, 0
SetBatchLines, -1
SetTimer, UF, 1000
UF: ;detects if mouse is hovering over Render and enables right click while it is
MouseGetPos, UX, UY, UW, UC
If(UC = "FFX::CustomDrawControl4")
   Hotkey, RButton, On
   Return
Hotkey, RButton, Off
Return
RButton::
SetMouseDelay, 0
BlockInput, MouseMove
Random, RANDM, 20000, 100000000
MouseGetPos, xc, yc
WinGetActiveTitle, AWT
ControlGetPos, eX, eY, eW, eH, Edit8, %AWT% ahk_class FFX::Form
MouseMove, eX+50, eY+15, 0 ;4K 3539, 1918, 0
Sleep, 100
Send, {LButton}
Sleep, 150
Send, {LButton}
Sleep, 150
Send, %RANDM%
Sleep, 500
MouseMove, xc, yc, 0
Sleep, 100
Send, {LButton}
BlockInput, MouseMoveOff
BlockInput, Off
Return
^ESC::ExitApp ;Control + Escape Exits App
Eventually I'll clean it up and add a GUI, one click auto export, random model, guidance, steps, height and width.
FF12 Environment Library By Valhalla - Go From ~10ish Built-in FFENVs To 327 FFENVs! mediafire.com/folder/5mof7pqxvs0fr/FFENV
Current Rig: AMD TR 3970X 32C|64T 4.5GHz CPU - Nvidia 24GB RTX 3090 GPU -128GB Ram And Two 4TB M.2s.
Valhalla
Valhalla
Read the first post for instructions on setting up and using AutoHotkey.
Added full randomization to steps, guidance and seed. Also added auto random number inserted when saving. Example: Kitty.png Forest.png will automatically turn into Kitty-238443.png Forest-1595.png then the cursor will automatically move to the save button. All functions can be disabled by removing the ; from the top and bottom.
Will turn into functions to clean up the code and add a gui/frontend that overlays in UFs blank space (only while UF is active) with text and checkboxes to disable functions and number inputs to change code randomness range soon. There are some images under the code the were made and saved in three clicks.
Valhalla
Valhalla
Deleted until I can get it to post without cutting off my code/images. Here's the the new code on pb https://pastebin.com/kn2CYQSZ
33,778 Registered Users
15,368 Topics
+54 new in year!
37 unregistered users.
