Valhalla
Valhalla
2023 10 Formatted Environments Folder New
2022 134 Formatted Environments Folder Old
2022 137 Unformatted Environments Folder -Oldest
I will add new environments to the 2023 folder in batches of 24 import hours (~14 Environments) on days I feel like working on it. So far I have a script that automatically imports the environment and deletes the EXR file. I just finished a photoshop batch file that cuts the images into four and saves them as .EXR because midjourney generates four images per prompt, the image size is 2048x1024 so it's perfect. All I need to do now is add code that automatically sends a list of prompts on discord to generate images, save them to a directory, rename the images to V-Env Type-Info-XX.exr, and run them using the batch file.
I would appreciate any help coming up with prompts to send. Here is the format if you want to help me with my work until I can get Chat GPT3 to generate a list. Examples below, if you make a list of prompts you think will turn out good, I will run them all. Also, I don't mind running some non filter forge related prompts, but please keep it PG-13 and don't ask for a bazillion.
An example prompt:
/imagine real life rick and morty looking at the ocean at sunset, ultra detailed, hyperrealistic or ultra realistic, 8k, (recommended for better images/photography can be replaced with cgi) award winning photography, art by artist and/or cyberpunk style or red green blue papercut style with multiple layers, HDRI Environment, --ar 2:1
A super simple prompt:
/imagine mountain landscape during autumn, HDRI Environment, --ar 2:1
,HDRI Environment, --ar 2:1 is required --ar 2:1 = aspect ratio and generates a 2048x1024 image with four images inside it.
It's nice to be back, I'll check this post tomorrow. smile:-)
-Valhalla
FF12 Environment Library By Valhalla - Go From ~10ish Built-in FFENVs To 327 FFENVs! mediafire.com/folder/5mof7pqxvs0fr/FFENV
Current Rig: AMD TR 3970X 32C|64T 4.5GHz CPU - Nvidia 24GB RTX 3090 GPU -128GB Ram And Two 4TB M.2s.
Filters: 268
I have been playing with DeepAI and have a small library of prompts that I use and play with. Incorporating FF with the final image and add some effects to it.
This is one of the prompts that I use and tweak. I added some of what you posted so might need some tweaking.
multiple exposure ICM photo of lights in the city streets, ultra detailed, hyper realistic , 55mm Canon Lens, f4.5, stacked photo, HDRI Environment, --ar 2:1
This is one of the results of this prompt.
Filters: 268
One of the tweaks that I do with this certain prompt is add a saturated color to it.
multiple exposure ICM photo of lights in the city streets, ultra detailed, saturated color, hyper realistic , 55mm Canon Lens, f4.5, stacked photo, HDRI Environment, --ar 2:1
Filters: 268
One more that I use is this one.....
passage and blind in the middle of a lake during a very sunny day, ultra detailed, saturated colors, hyper realistic, HDRI Environment, --ar 2:1
One of the results from the above in DeepAi. You can also exchange saturated colors for bright colors.
Valhalla
Valhalla
Heya, thanks, this will be great help when creating prompts! The first prompt works extremely well in both midjourney and stable diffusion 2, I adjusted the weights a little. Here's the results of your prompts on my discord server dedicated to AI art. I ran them 20+ times.
Oh yeah, feel free to upload the images, even older ones I made, I don't have time for the next few days.
Thanks again,
Valhalla
33,778 Registered Users
15,368 Topics
+54 new in year!
14 unregistered users.
