Valhalla
Valhalla
Sorry for being gone so long, I had no clue how bad the depression I am dealing with is. Last paragraph for the important info. Anywho, I came across my next love, text to image recently and can get awesome environments by simply explaining what I want. I've generated a couple hundred images that I still need to convert into FFENVs using prompts like
desert landscape hdri environment, high-quality, artistic, unique, award-winning photography, dynamic lighting, --ar 2:1 make images like this.
Also stuff like this dragon using a prompt like rgb papercut style, dragon, multiple layers. Since I own topaz gigapixel I have no need to upscale and use any of my 15 hours fast compute time on midjourney. I had my own setup with 24GB of VRAM and was able to gen images good as MJ, but my GD SSD went out and I lost my setup and 3.8TB of 20GB combined models I spent months creating. In the process of redoing everything, but MJ pro for 15 fast hours will have to do for now. 15 fast hours = ~3000 images that are the perfect size for filter forge environments. I say this because you can get 15 free outputs monthly IIRC and make/convert your own environments of whatever you can think of, just remember ,--ar 2:1 for the resolution. If you want to run it on your own pc at minimum you need 12GB VRAM so a 3060 or a 3090 & 128gb ram for the best results. Look up invokeai or stable diffusion to get started.
I want to continue my Filter Forge environment project, so on my best day of the month, the 25th, I will spend it on FFENV creation on my second newest pc that way it can churn out the workload over the week or two it will take. My script does a few things, cuts the generated images into four, uses software to convert the images to exr, and automates the ffenv import process in filter forge. I'm not going to put a heavy workload on myself when there is no need and my doctor said it's bad for my state of mind. Anyways, I still have much love for the FF community! Cya on the 25th.
FF12 Environment Library By Valhalla - Go From ~10ish Built-in FFENVs To 327 FFENVs! mediafire.com/folder/5mof7pqxvs0fr/FFENV
Current Rig: AMD TR 3970X 32C|64T 4.5GHz CPU - Nvidia 24GB RTX 3090 GPU -128GB Ram And Two 4TB M.2s.
33,778 Registered Users
15,368 Topics
+54 new in year!
14 unregistered users.
