Elynde
Posts: 3 |
| Posted: November 9, 2022 3:26 pm | ||||||
Adam P
Posts: 2 |
I have exactly the same problem. Filter Forge wrote in the technical requirements note: Affinity Photo 1.8, 1.10.4 and NEWER! - But Affinity 2.0 not supported, what I have to do? Will there be an update? When installing versions 11 and 12, it does not detect Affinity Photo 2.0 Only standalone version. Will there be an update? Why is no one answering me, on messenger or e-mail?
Adam |
| Posted: November 11, 2022 4:15 am | ||||||
You get this when Filter Forge is not compatible with that version of whatever application you are installing it into. This is also the error you get with photoshop. I have made a video of how to fix this error in photoshop. So I would guess that if you find where the plug-in is installed in Affinity and change the needed config file then it would work. There is no guarantee since I do not have Affinity Photo to try it out and see if it does or not.
Here is the video for photoshop so skip through until you see me open photoshop in the video the second time. Around the 3 minute mark. Installing Filter Forge Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: November 11, 2022 9:16 am | ||||||
Posts: 3498 |
The system requirements are Affinity Photo 1.8, 1.10.4, and 1.11: https://filterforge.com/download/ We are working to add a compatible plugin for Affinity 2.
We only provide support via the contact form. |
| Posted: November 11, 2022 11:25 am | ||||||
Adam P
Posts: 2 |
Yes! Yes! It works on Affinity Photo 2.0! Thank You Very Much Adam |
| Posted: November 13, 2022 8:26 am | ||||||
Elynde
Posts: 3 |
Yes! I can also confirm this very simple fix works in Affinity Photo 2.0.
| Posted: November 13, 2022 2:44 pm | ||||||
33,758 Registered Users
15,361 Topics
