jess
jess
when i use the droste effect spiral, i get pix with angular spirals. how do i alter the filter to get rounded spirals?
jstech
do you have an example of what you get and you do not like?
And do you have an example of what you mean with rounded spirals?
If what you want is that the sides are not straight and linear, you need to load an image that has transparent background with the shape that you want
For example in the presets you find this
and if you want to remove the rectangular tiling you need to remove the gray background, so instead of loading the full lifesaver image, you need to load the same built in image WITHOUT the background
So you get this shown here below
This is how I have made the examples shown here
All these 3 images sources are circular objects with a transparent background, so when loaded into the filter it will create a rounded circular spiral
David Roberson
Artist
Just an added note: For the built-in preview images you need to go under File/Built-In Preview Images/ and click on Use Transparency at the bottom. It is also possible to load a grayscale image as a Selection, also under File. You would do this if you're using Filter Forge in stand-alone mode and need to use a filter that requires a selection. Just remember that the image you are editing and the grayscale image you use as the Selection need to have the same resolution and aspect ratio.
33,769 Registered Users
+28 new in 30 days!
15,366 Topics
+61 new in year!
25 unregistered users.
