westdale
Filters: 7
(Win 10 ) Librarian by default installs on the C: drive. This means that my two machines (especially my solid state laptop with limited space) have to carry a GB of data.
I tried moving the library to my shared drive where all my other FF work sits. Librarian took in a location for the library but the load failed. Having done this, I gave librarian the original location but that gave the same error.
I uninstalled and reinstalled to the default place - and that is still failing, remembering the shared drive location - presumably in the registry somewhere.
Ideas please for (1) shared drive use or (2) how to get Librarian working again even if on the C: drive!?
westdale
Filters: 7
Part 2 solved. The uninstall doesn't remove AppData/Roaming items so the link to shared drive confused the reinstall.
Part 1 still of interest to avoid multiple copies of the library - can one use the 'location' option in Library to indicate a shared drive?
What particular files/folders did you move from what location?
Also, by 'shared drive' do you mean a network location or a removable disk?
33,752 Registered Users
15,359 Topics
