Beat
Beat
I would like to know if there is a way to stop the rendering and still keep the result. Of course only rendered to the precision of the moment of stopping the rendering.
I want this because of the following two reasons :
1. Very often I like what I see in the preview (rough rendering) better than the final result. I have the same experience with some Topaz plugIns. So I'd like to step out of the process at a certain point, but with a result.
2. I just had an image being rendered for 35 hours. I don't mind waiting a bit, but this was too much. I let it render, because the result seemed to get beautiful. But alas, the final result was again less good than the intermediate screen preview (see my point one).
Is there a possibility to escape the process, but with retaining an image with the rendering up to that point? Cancel does not work (no result) and (Mac) command + period also no dice.
A solution would really help me.
Beat
Well, sort of.
In this case, grab the preview instaed of the final result. After the preview image has finished rendering, press Ctrl+C, switch to your favorite image editor and press Ctrl+V.
You can do the same with Draft Mode previews: enable Draft Mode, wait for the preview to finish, then copy-paste it.
Beat
Beat
This is great, thanks a lot GMM smile:-)
I could not find what you mean with 'enable Draft Mode' and the Help menu does not show any results.
Where do I enable the Draft mode?
Cheers, Beat
I think that for this you are using the 4 steps preview so it starts rough, and on each steps goes adding more detail.
I have done this already sometimes making a screenshot of the render in Actual Size mode but of course this would only work for the screen resolution size, I mean that you can only take what the monitor screen can take.
OH! I did not know that you could copy the FF result before it has finished rendering. So this would copy it at the resolution that is configured ? Will have to try it
The Draft Mode is only available in FF 10.0 and the problem I see with this is that the Draft mode has lower quality to make it faster and as far as I know is not intended for final result, although if you really like the quality it may give then you may use it
33,778 Registered Users
15,368 Topics
+54 new in year!
17 unregistered users.
