The_Funktasm
"SALT THE FRIES"
So recently, as in the past few weeks, I've had what seems at first like a crash of FF when using the export function, but eventually, given an hour or so it will export files.
This happens with filters my computer can render each map of in up to five minutes. Export wasn't doing this before either. I don't suppose this is an error that's already known of?
EDIT: I attempted this again and this is the length I wait until I pick somewhere to save the results. Not the render time.
I'm afraid that's not enough for us to troubleshoot your issue.
- What filter are you using?
- What image dimensions are you using?
- What is your Filter Forge version?
- What render channels did you select? Is Final turned on or off?
The_Funktasm
"SALT THE FRIES"
I believe it was a temporary issue as it seems to have ceased. I have not had the problem happen in months.
Also, when it WAS happening, it happened with filters that are built in and filters I made or downloaded. So it seemed to be all of them at the time. Not any specific filters.
33,771 Registered Users
+12 new in 30 days!
15,367 Topics
+57 new in year!
18 unregistered users.
