Paul Clavette
Paul Clavette
Filters: 3
Hi All
The plugin does not seem to work on my Mac with Photoshop CC 2017.
I get the error message:
"Could not complete the Filter Forge 6 command because of a program error."
As anyone else had this problem and is there a way to fix it ???
Thanks !
Paul
Does standalone FF6 work for you?
Paul Clavette
Paul Clavette
Filters: 3
Yes it does !
No problems with the standalone !
Paul
Please try to copy the entire "Filter Forge 6" folder from /Applications/ to /Applications/Adobe Photoshop CC 2017/Plug-Ins/Filters and check if it helps.
Paul Clavette
Paul Clavette
Filters: 3
Thanks GMM
Have done this and it works just fine that way.....but makes the Photoshop folder a little heavy !!!
Any other way around this and is there going to be a fix eventually ???
In any event, I have enough space for it and I do thank you for the help and solution.
Take care and have a good day !
Paul smile:)
Yes, you can create an alias (Alt+Command+mouse) for the “Filter Forge 6 universal x86.plugin” file in the Photoshop’s Filters folder. However this method fails for some users... while copying the entire folder seems to work for everyone. Don't really know the reason.
33,757 Registered Users
+25 new in 30 days!
15,361 Topics
