jhantares
Filters: 272
MosPat Generator 32 by jhantares
http://www.filterforge.com/filters/14097.html
jhantares
Filters: 272
How to use this filter
This filter generates patterns using 6+2 different pattern sources.
You can alter gradient and pattern by using assigned sliders.
See following lines on how to use sliders.
Component shortcuts
GRx -> Color/Gradient controls
RO -> Rotate component
K1,K2 -> Kaleidoscope component
MO -> Bricks component
ND -> Noise Distortion component
HSL -> Hue component
Set "GR-Selector 1" to 1
Use sliders: "GR13"
Set "GR-Selector 1" to 2
Use sliders: "GR2-Scale 1", "GR13"
Set "GR-Selector 1" to 3
Use sliders: "GR3", "GR23", "GR13"
Set "GR-Selector 2" to 1
Use sliders: "GR23", "GR2-Scale 2"
Set "GR-Selector 2" to 2
Set "GR-Selector 2" to 3
All patterns are altered by sliders: "GR", "RO", "K1".
Use "BG" control to select background color (in case of transparency would be shown).
Check "Mosaic on" to use "MO" sliders.
Check "Distortion on" to use "ND" sliders.
Check "Kal on" to use "K2" sliders.
Check "Hue on" to use "HSL" slider.
33,756 Registered Users
15,361 Topics
13 unregistered users.
