FFCreator
FFCreator
FFEasyRender is a (free) GUI based (background) renderer for Texture and Effect filters of Filter Forge.
This is my approach of a batch renderer for Filter Forge.
You can download and use it for free.
FFEasyRender stays on top of other windows so it is possible to use it together with Filter Forge. It is possible to interactively define render tasks, add these render tasks to the (virtual) render queue and then to render the complete render job with the render tasks in the background. You can select multiple presets to render. You can select 1 or more source images to render when the filter is an effect filter.
Tested with Filter Forge 4. At the moment (29-11-2015) some bugs in the commandline renderer of Filter Forge 5 (release version) prevent the use of FFEasyRender with Filter Forge 5. This should be solved with Filter Forge version 5.007 (see beta Filter Forge forum).
More info and (free) download :
FFEasyRender - IPadTouches.com
FFCreator
FFCreator
Interesting smile:deer:
FFCreator
FFCreator
The password to download the zip file is listed on the webpage, see first post.
The zip file contains the program (V1.0) and quick start manual (PDF).
No need to install, not crippled, no malware, free, not time limited.
Tested with FilterForge 4 Professional.
Should work with other versions (2-5).
Should work with version 5 from 5.007 (not released yet) and above.
Let me know your experiences and if you have problems.
FFCreator
FFCreator
I can confirm that since version 5.007 of Filter Forge my program is working with FilterForge 5 too. smile:)
WOW! i have just discoverd this and seems to be very good, useful and interesting, thanks very much for making it
LexArt
LexArt
This seems to be very useful and interesting
Thanks very much for making it
Will test and see how it works
TomE
Excellent work, thank you.
FFCreator
FFCreator
I have updated Filter Forge Easy Render (FFEasyRender) to version 1.1.
Changes from version 1.0 to 1.1:
– support for (64 bits) Filter Forge 6;
– extra option to shut down your PC after the renderjobs have finished;
– some bugfixes.
This update is also free (donationware).
See: Filter Forge Easy Render V1.1
paulcopeland
Paul from Australia
Thank you FFCreator for your great program which I used a while back.
I now have FF 7 for Windows 10.
Have your updated your great program to this version?
If not I would be more than happy donating some money to the development of an update.
Best wishes and bye for now.
Paul from Australia.
Winner Jean Bogan Piano Composition Competition 2016
33,758 Registered Users
+7 new in 7 days!
15,361 Topics
14 unregistered users.
