A tiny little convenience function I would love to have in the Filter Forge main window: An Option to force Seamless Tiling for filter rendering. This should override the setting embedded in all filter presets, and could be conveniently grouped with the Anti-Aliasing and Render Maps options in the Filter menu.
Thought about this myself some time ago. Added to the long-term list.
Sweet! smile:beer:
This would make evaluating presets and their soon-to-be look on the web filter library much more convenient.
While we are on the topic of render overrides: Correct me if I am wrong, but the anti-aliasing options appear to be linked to the presets too. Would be nice to have a global override here as well that generally turns off the anti-aliasing pass.
Ad Majorem Dei Gloriam
I, too, would appreciate this feature
----Your are correct, hours/days later, I just realized this was causing me big probs too, this needs to be changed BADLY, please, global anti-aliasing control. smile:D
+ 100 a pain having to do each preset individually if you want to change the settings.....
.....and since where on the subject of "Global Control".....it would be nice to have it for lighting as well smile;) smile:)
very good ideas! i'm in favor of these globals also!
Result Component > Filter Type: Simple Filter smile;) smile:D
Let me re-phrase it smile;) smile:D If you want to change a lighting value shared by all your presets, then you could just select all presets and change them all at once.....instead of having to change each preset individulally.....
But why would you want to have all your presets use the exact same lighting? Lighting brings variety...
MysticBlueRaven
Texture Artist/ Cavy Slave
Filters: 75
I agree with Crapadilla, I just wish we had more control over the lightiing.
Very true..... Almost all of my surface result filters use just one lighting scheme.....because it is impossible to avoid bad areas in randomization (which is why I wish you could set lighting parameters and choose which lighting to include).....and because I want the user to stay in the best lighting for the best effects without the chance of being misled and stuck in a less desirable lighting scheme. I probably shouldn't do it, but I do approach the least experienced user with my filters.....
Anywho, even though I only use one lighting scheme, they still seem to be very useful with many turning HU.....but I hear what you're saying by all the Editor's Picks that I have smile;) smile:D
I agree 110%.....would make it much easier (for at least me) to include other lighting for more variety as Dilla stated......
In the light of recent render speed discussions, I thought I'd bump this, and reiterate.
[*] Global Force Seamless Tiling Override
[*] Global Anti-Aliasing Override
These are just... a necessity! smile:D
YES, YES !!! I totally agree with you, it would be really good and a very useful thing to have and so be able to override the presets values, great suggestion and request
11 unregistered users.
