voldemort
voldemort
Filters: 649
I wish I could find search function for theese forrums because this has probably allready been brought up but autosaving the filter every couple minutes would be invaluable. I dont know how many times the program has crashed and I lost a bunch of work (and yes I know first rule is allways save as you work but sometimes when you get engrossed you forget) maybe if it saved it under the name
autosave...
that way if it crashes you could pick up from where you left off
Thanks
Interesting. The last beta is quite stable and shouldn't crash often. Have you submitted the bug reports for those crashes? (when Filter Forge crashes, it offers to submit a bug report automatically). We'd like to look into this.
voldemort
voldemort
Filters: 649
errr --no I havnt been good about submitting my bugs to be frank I tend to be to bussy being pissed off and hitting the case on my computer when anything crashes
Ill make sure to give my case a break and click submit for now on
Bad Voldemort--Bad Voldemort
voldemort wrote:
voldemort Posts: 17 errr --no I havnt been good about submitting my bugs to be frank I tend to be to bussy being pissed off
All you have to do is to hit the Send button -- everything is already filled in, you don't have to type anything.
voldemort
voldemort
Filters: 649
Yeah I realize this I just normally hit cancel Like I said for now on Ill make sure I click submit
Though Just as a side note it tends to happen on my 64 bit machines more than the 32 bit ones
SV Perry, 8 unregistered users.
