Aram Azhari
Aram
Anyone who use FF for games know that exporting the maps is a time consuming task.
I suggest an easier way to export maps from the Save menu so we can actually export them all at once or select some checkboxes for the maps we want to export. (Checkboxes are saved in registry or something so you wouldn't have to click check boxes again!)
The current usual map we use in games are:
Diffuse
Bump
Normal Specular
Alpha
So if you were to export them, you will do this 20 times:
1- Choose the material
2- Click on Filter menu
3- Click on Render Maps submenu
4- Click on a map.
See my point?
Thank you again and I will leave you with a smile. smile:)
___________
Aram Azhari
Voltago
+1
would be a huge time saver!
This is actually a request since 1.0! smile:D
And probably will still be a request in FF 5.0 and FF 6.0 as MANY other things that has been requested
~10 years later~
Sharandra
Filter Forge Addict
+100000 smile:-)
Please check over the new Export dialog in FF7.
