When you go to the online FF library, all the 600x600 previews and all the presets thumbnails and variation previews pages are already pre-rendered and available instantly.
Also this happens with the presets available inside each of the filters of the FF library inside the application
BUT when you go to the Filter Forge Browser to see for downloading more filters, THERE IS NO pre-rendered thumbnails for any of the filter or the presets
I think that there should be a way to for FF to make already pre-rendered presets for showing inside the Filter Forge Browser as it happens in the online library, because it needs to MAKE AND RENDER ALL the thumbnails in real time as you click over one filter AND the same for any preset found inside this filter.
This is not a problem if the filter is fast, BUT if the filter is slow you will have to wait a lot until you can see a simple thumbnails AND will have to wait a lot for EACH ONE of the presets as they need to be rendered in real time and is not available any kind of pre-rendered previews which should be the best way to avoid and fix this.
Please, why we have to wait for EACH ONE of the presets to be rendered ?
Is really boring and time wasting
Please, Please, could be possible to have in FF 4.0 a Filter Browser inside FF WITH Pre-rendered previews for filters and all it´s own presets ?
So this way it will be MUCH faster and easier to browse for new filters and will be the same like doing it on the FF online library.
Thanks very much.
I don't suppose this is going to happen EVER.
The Filter Browser is deemed obsolete, meaning it's dead to FF dev team. They won't update anything about it, and they don't care about it.
Consider the fact that they won't even have a very easy to do "Show ONLY downloaded filters" option...
