ab30
Hello, it would be fine to have the possibility to configure the workspace.
I mean: to have panels that are resizable (already they are), dockable (floating windows), moveable, or that can be hidden.
For the editor, by example, isolating the following panels so that they can be rearranged in the workspace:
-Preview
-Settings
-Components
-Mapping
Thanks,
ab30
ab30
Also, i came upon this limitation of one editor window opened at a time.
Multi-Filters Editing and copy/paste components between Filter Editors would be also appreciated.
Thanks,
ab30
ab30
Finally, for this evening, and as i don't want to exagerate with the quantity of requests, the software being already a great product, i would put my vote for a "multiple results" filter output with a controler for switching between render outputs into the main filter properties panel (possibly into multiple tabs as it has already been discussed into the forum).
In resume, i would have asked for
1)Flexible UI & Resizable Panels
Draggable, resizable and floatable panels and containers that can also be minimized or hidden like in floating windows mode.
2) Customized components groups easily moveable from one filter to another (if no multi-filter editing allowed)
3)Multiple Render outputs (multiple results node) and option for switching between the selected outputs into the main filter properties panel. Already exists via the SWITCH component.
Thanks again for taking all this into consideration,
ab30
YES, YES good idea and great suggestion, as this is the standard for lots of others softwares available in 2012 where you can have a customizable and flexible UI and you can dettach the panels and make them floating and you can move them and resize them as you want.
