I know that Filter forge uses the square tiling to be able to make the seamless tilings, as this one is the simplest and easiest to do.
BE AWARE - Possible Crazy idea suggestion and Vladimir would scream smile:D
BUT, this is not the only way that a seamless tiling can be made, as there are other many ways to make tilings as shown below
Instead of ONLY using the square tiling, Filter forge could have a choice of tiling and choose different shapes to tile the base image and the filter result into those different shapes as shown above.
Why limit the tiling only to the square one ? ( I know is the simplest and easiest to make)
TRIANGLE TILING
HEXAGONAL TILING
STAR TILING
An more complex tiling like the DODECAEDRON TILING
And much more complex tilings like the PENROSE TILING
PENROSE TILING MORE EXPLAINED IN WIKIPEDIA
And there are many more
And if you think that this is impossible to programm and use this kind of tilings with photos you are wrong, as these has already been released and are available in this other software called Kaleidoscope Kreator 3
I thought I saw a similar post regarding tiling methods ages ago. It's something I'm still interested in seeing in future versions regardless.
WOW!! Has this been suggested before ? I thought that this was a crazy idea, but seems that I am not the only one smile:D
You have very good memory as this is true, it has been already suggested in 2006 by uberzev with a very good wikipedia article that show perfectly what I am suggesting
Please see this for very good examples --> http://en.wikipedia.org/wiki/Tilings_...r_polygons
you can see that old thread here
Been on FilterForge forums since the first version of the Mac edition of FF appeared. I can recall the suggestions I still pray for.
Clicky!
Yes I know that there are these have been requested the 17 Wallpaper groups, thanks smile:) smile:) but as usual, Vladimir does not add them later, this was in 2009! and there is no further news about them
Well this was thread was done in 2011 and I still thinking about making all these kind of different tilings in Filter Forge as it happens already in the Kaleidoscope Creator 3 , and I think that in FF 6.0 or FF 7 with the new greenified components it could be possible to make in some way
Sorry that I do not know if there is already any Kaleidoscope filter that is able to make any of the tiling suggested in the first post
Crapadilla made a reference to the 17 wallpaper groups
Clicky!
And in 2015
17 WALLPAPER GROUPS BY RACHEL DUIM
Rachel Duim made already as filters all these awesome and amazing 17 wallpaper groups, well done AND with preview
17 Wallpaper groups by Rachel Duim
