Need a "Fixed Size" option on all components tied to the global size control (like on the Frame component)...so that you can disable certain components in order to keep the useful size control on the filter. A global disconnect was never needed...just a component option, IMO...
Try this...
Fixed Size.ffxml
Hate to ask this (since I've done it in the past)...but how do you open them in FF...coming up as script readouts... No such thing as a stupid question, right??? smile:D
From Windows
Right click on attachment to save to desktop
From desktop double click on file
If that doesn't work...
From the desktop Right click on the file and select "Properties".
Next to wh ere it says "Opens with:" click the "Change..." button.
Select FilterForge
some time ago it changed, right click on the file above, choose save as, you'll have to add .ffxml, save it to your desktop, double click and it will open in FF smile;)
16 unregistered users.
